What is the final temperature of a glass mug filled with hot water?
The discussion revolves around calculating the final temperature of a glass mug filled with hot water, assuming no heat loss to the environment. The user initially struggles with the equations for heat transfer, specifically how to account for the temperature changes in both the mug and the water. They clarify that the final temperature will be the same for both, leading to the substitution of the temperature change formulas. After applying the correct substitutions and calculations, the user arrives at a final temperature of approximately 76.46 degrees Celsius. The conversation highlights the importance of understanding heat transfer principles in solving thermal equilibrium problems.
jakeowens
A 330-g glass mug at 16C is filled with 275 milliliters of water at 91C. Assuming no losses to the external environment, what is the final temperature of the mug?
Im having a bit of trouble with this problem. Since we're assuming no losses, delta q=0.
So, delta q= delta q(mug) + delta q (water) = 0
and delta q(mug) = mass(mug)*specific heat(mug)*delta T(mug)
and delta q(water) = mass(water) *specific heat(water)*delta T(mug)
so put it all together and i get
0=.330kg*840J/kgK*delta T(mug) + .275kg*4186J/kgK*delta T(water)
But where do i go from here? Is the change in temperature for botht he mug and the water going to be the same? in which case i could factor out a delta T, but then that still leaves me stuck.
Does the change in temperature of the water even matter at all?
Theres got to be a way to do this that I am not seeing...
Thanks
It is the final temperature that is the same for both. They both have their own initial temperatures, right? "Delta T" means "final T minus initial T." So substitute (T_f - T_o) where the delta T is.
sweet thanks. that pointed me in the right direction i do believe
i substituted (Tf-To) for delta T, and solved for Tf coming up with a final temperature of 76.46 degrees celclius. that sound right?
thanks again for the help
okie dokie. I don't have my calculator handy, but that seems aobut right.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
