What Is the Final Velocity of the Black Ball After Collision?
  • Thread starter Thread starter Dreaam
    Collision Exam
The discussion revolves around calculating the final velocity of a black billiard ball after it collides with a white ball. The black ball initially moves at 1.5 m/s and strikes the white ball, which is propelled at a 35-degree angle with a final speed of 0.9 m/s. Participants point out errors in the calculations, particularly in the use of sine and cosine for the x and y components. The correct final velocity of the black ball is determined to be 0.87 m/s at an angle of 56.30 degrees north of east. The importance of maintaining symbolic calculations until the final step is emphasized to avoid mistakes.
Dreaam
Collision Question: (URGENT) Exam tomorrow
Hi all,
I have an exam on collision and projectile motion tomorrow, and was wondering if anyone could answer this question: I get an answer, but my friend gets a completely different answer. I was wondering if anyone could just clarify and show us the correct answer. All help greatly appreciated. Thank you for your time.
A black billiard ball travels up the centre line at 1.5 m/s. It's mass is 250g, it strikes a white ball of the same mass which is propelled at an angle of 35 degrees to the left of the original direction of the black ball. The white ball final speed is 0.9 m/s. What is the final velocity of the black ball?
m1u1 + m2u2 = m1v1 + m2v2
tanθ = sinθ/cosθ
This is what I did:
Find x and y components of the unknown final velocity's vector's magnitude.
Let Vb = Velocity of black ball
θb = angle the black ball is moved in after collision
x-component:
(0.25 * 0) + (0.25 * 1.5 cos 90) = (0.25 * 0.9 cos 125) + (0.25 Vb cos θb)
0 = -0.13 + 0.25 Vb cos θb
0.13 = 0.25 Vb cos θb
Vb cos θb = 0.13 / 0.25 = 0.52 m/s
y-component
(0.25 * 0) + (0.25 * 1.5 sin 90) = (0.25 * 0.9 sin 125) + (0.25 * Vb sin θb)
0 + 0.375 = 0.18 + 0.25 Vb sin θb
0.375 - 0.18 = 0.25 Vb sin θb
0.195 = 0.25 Vb sin θb
Vb sin θb = 0.195/ 0.25 = 0.78 m/s
So from this, using the magnitudes a right angle triangle can be formed:
positive 0.78 (north direction) being the vertical side
positive 0.52 (east direction) being the horizontal side
to find the resultant vector
r = sqroot (0.52^2 + 0.78^2)
r = 0.87 m/s
to find the direction:
tanθ = sin θ / cosθ
tanθb = vb sin θb / vb cos θb
tanθb = 0.78 / 0.52
θb = tan^-1 (0.78 / 0.52)
θb = 56.30
Therefore: the black ball after collision is moving at 0.87 m/s in a direction of 56.30 degrees north of east.
Could you please post a picture showing the directions and θ?
I've attached the file.
Edit: Sorry the angle should be 35.
You shouldn't still have a .25 in there.
Here's a really good piece of advice: work entirely symbolically until the last step. Only then plug in the actual numbers. This makes it much easier to find mistakes and for other people to follow what you are doing. In the above, you might then have spotted that the dimensions didn't make sense, having removed mass from all except one term. It also helps to preserve precision and minimise calculation because you often get cancellation in the algebra.
Thank you for your feedback haruspex, my question is: even if I included the 0.25 values, wouldn't the outcome still be the same? Or have I made a mistake along the way?
You've jumbled up sin and cos mate. x-component will have sinθ and y-component will have cosθ. Change that and solve again.
No, it is an error that will change the answer. You canceled the 0.25 out of three terms but missed the fourth. You made the same mistake in the y direction.
siddharth23 is also right - you've mixed up sin and cos on the RHS of your equations.
I see where I went wrong. Thank you everyone for your feedback.
Anytime mate..
