What is the final volume of the container?
The discussion revolves around calculating the final volume of a container with a piston, heated for 15 seconds by a 25 W heater. The initial conditions include a volume of 800 cm³, pressure of 1.11 x 10^5 Pa, and temperature of 20°C. The initial approach incorrectly applied the ideal gas law, leading to an unexpectedly large volume calculation. After clarification, it was established that the container is filled with a monatomic gas, necessitating the use of specific heat capacity for gases. The final calculation yielded a volume of approximately 1.00135 x 10^6 cm³, but concerns about the accuracy of this result were raised, prompting further checks on unit consistency.
houseguest
A container has a 100 cm^2 piston with a mass of 10 kg that can slide up and down vertically without friction and is placed below a heater.
Suppose the heater has 25 W of power and are turned on for 15 s. What is the final volume of the container?
Initial Volume: 800 cm^{3}
Initial Pressure: 1.11*10^{5} Pa
Initial Temperature: 20 C
pV = nRT
Q = p_{power}\Deltat = nC_{p}\DeltaT
Using pV = nRT and knowing that p_i = p_f I can get V_{f} = V_{i}T_{f} / T_{i}
I now need T_{f}
To get that I used
to get
T_{f}] = p_{power}\Deltat/nC_{p}] + T]_{i}
Then I used p_{i}V_{i} = nRT_{i} to replace n and I got (after much simplifying)
V_{f} = p_{power}*\Deltat*R/[ p_{i}C_{p} ] + 1
I then plugged in all the numbers (using C_{p} of water = 4100 and got:
25*15*8.314/(1.11*10^5*4100) + 1 = 1.00000685 m^3
Which gives \approx 1.000006.85 * 10^6 cm^3
I have a very hard time believing that is the answer -- it's just too large.
Any help pointing out the stupid thing(s) I did would be very appreciated!
THANKS!
Hi houseguest,
Did you type in the entire question? You used C_p of water in part of your solution, but I don't see where water appears in the problem.
Sorry, I forgot to mention that the container is filled with water.
I hope I'm not misunderstanding the problem. However one point is that if the container volume is increasing because it's filled with water and the water volume is increasing, then you cannot use PV=nRT. (That applies to ideal gases.) Instead use the formula for volume expansion of a solid or liquid.
Wow! I'm sorry, that was definitely one of my stupid things. Thanks for pointing that out! The container is filled with a monatomic gas. So I should be using C_p for that.
So, since C_p = R + C_v and C_v = 3/2 * R ( for a monatomic gas) then C_p = 5/2 * R
So that would give ( with the R's canceling)
25*15/(1.11*10^5 * 5/2) + 1 = 1.00135 m^3 = 1.00135 * 10^6 cm^3
However, this (I would think) is still too large. Any ideas?
Thanks for your help!
I see at least one error involving R. Try carrying your units along with each term to make sure everything cancels out OK.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
