What is the formula for calculating the speed of light in a medium?
To calculate the speed of light in a medium, the formula used is v = c/n, where v is the speed of light in the medium, c is the speed of light in a vacuum (approximately 3 x 10^8 m/s), and n is the refractive index of the medium. For water with n = 1.33, diamond with n = 2.42, and quartz with n = 1.54, the respective speeds can be calculated using this formula. The discussion emphasizes the importance of showing work in calculations as per forum rules. Participants are encouraged to provide specific details when seeking help. Understanding the formula is crucial for accurate calculations in physics.
RoseCrye
1.Find the speed of light in the following in m/s...
(a) water (n = 1.33)
(b) diamond (n = 2.42)
(c) quartz (n = 1.54)
i can't seem to get any of these right...
Please show some work. Its the rules of the forum. We're not supposed to help you until you do.
looking for a formula...
ooops. sorry, didn't think about that. problem was, i wasn't even sure how to do it. didn't have a formula, and i couldn't find one. that was really what i was looking for... i'll try to be more specific next time.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
