What is the general approach for calculating tension in different situations?
The discussion focuses on calculating tension in a rotating ring in a gravity-free environment, using two methods that yield the same result for tension. The first method involves equating the tension to the centripetal force required for rotation, while the second method relates tension to the work done by tension as the radius increases, linking it to changes in kinetic energy. Participants confirm the validity of the second method and suggest breaking the ring into discrete points to better understand the derivation. The conversation emphasizes the importance of understanding the relationship between tension, work, and kinetic energy in various contexts, including electromagnetic fields and rotation. Overall, the participants clarify their reasoning and enhance their grasp of the topic.
ShakyAsh
Hello people,
So i found out the tension in a ring rotating with constant angular velocity (in gravity free space)
Considering a small element of mass dm - tension will provide the centripetal force,
2Tsin(dθ/2) = dmrω^2
sindθ ≈ dθ
dm = m/2πr ds
ds = rdθ
T = (mrω^2)/2πNow, the other method
K.E. = K = 1/2 Iω^2 = 1/2 mr^2 ω^2
If we increase the radius from r to r+dr, then work done by tension
dW = T d(2πr) = dK
T = 1/2π dK/dr
T = (mrω^2)/2πEven though i get the same result, i have a doubt whether the second method is correct
I know that F=-dU/dr , but whether T=dK/ds , i don't know
Also, i want to know the general approach of calculating tension in situations like electro-magnetic fields, rotation & all.
Regards
ShakyAsh said:
2Tsin(dθ/2) = dmωr^2
Typo: you mean dmrω^2
K.E.= K = 1/2 Iω^2 = 1/2 mr^2 ω^2
dW = T d(2πr) = dK
T = 1/2π dK/dr
T = (mrω^2)/2π
I can't think of a justification for that method. Can you describe your reasoning here?
Yeah dmrω^2 , sorry
As i said, if radius of the ring is increased by dr, then work done by the tangential force tension will be T*(change in circumference) which will be equal to the change in kinetic energy which in this case is the rotational energy.
Yes, the approach is valid. If you have doubts, you can replace the ring by N discrete points with tension T between them and derive dW=T ds for N->Inf.
Dividing it into N discrete points, why didn't i think of that?
Anyways, thank you very much.
I think i understand it now.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
