A What is the heat capacity of water in meta-stable equilibrium?
The heat capacity of water does vary with temperature, but it remains relatively consistent across different states, including super-heated and super-cooled conditions. Super-heated water above 100°C and super-cooled water below 0°C do not undergo phase transitions, which affects their heat capacity. Specific heat capacity can be tabulated under isobaric (constant pressure) and isochoric (constant volume) conditions. The discussion highlights the need for clarity on which conditions are being referenced when discussing heat capacity. Overall, understanding these nuances is essential for accurate thermal calculations involving water.
ORF
TL;DR Summary
Dear experts,
I noticed that super-heated water (liquid water with temperature above 100*C) undergoes boiling when pushed outside the meta-stable equilibrium.
I was wondering, is the heat capacity of liquid water above 100*C the same as liquid water with temperature between 0*C and 100*C?
Similarly, for super-cooled liquid water (liquid water with temperature below 0*C), is its heat capacity the same as liquid water with temperature between 0*C and 100*C?
Thank you for your time.ORF
Google gave me literally hundreds of tables and charts. Your answer must vary with temperature, but does not greatly diverge from one.
If these are not what you want, you need to be more specific. Note that if water is superheated or supercooled, it has not undergone a phase transition. By definition.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
