What is the height of the cliff above the water?
  • Thread starter Thread starter aksarb
    Height Water
To find the height of the cliff, the rock's initial velocity is 8.3 m/s downward, and it falls for 6.9 seconds. The relevant equation to use is Δd = v1 Δt + 1/2 a (Δt)², where a is the acceleration due to gravity (9.8 m/s²). Substituting the values into the equation will yield the height of the cliff above the water. The calculations confirm that this method provides the correct height measurement. The discussion emphasizes understanding the physics principles and applying them correctly to solve the problem.
aksarb
You throw a rock off a cliff, giving it a velocity of 8.3 m/s straight down. At the instant you released the rock, your hiking buddy started a stopwatch. The rock hit the water below exactly 6.9 seconds after you threw the rock. How high is the cliff above the water?
Δd = 1(v1+v2)Δt
2aΔd = v2^2 - v1^2
Δd = v1 Δt + 1/2 a (Δt)2
Δd = v2 Δt - 1/2 a (Δt)2
I am assuming that the v1 is 0 because it starts from rest and v2 is -8.3m/s. (Sign convention was down negative.) and time was 6.9. I subbed everything into the equation. When I make everything equal to Δd, does that give me the height of the cliff above the river?
All you need is the s = ut + 1/2at^2
But the initial velocity u=8.3 and a=g=9.8m/s^2
Don't try and remember the sign convention, think about would S get bigger or smaller with time, would a large U reduce/increase S.
So, it would be:
D = (8.3m/s)(6.9s) + 1/2 (9.80/ms^2)(6.9s)^2
Work it out and the D would give me the height?
Yes (and some more unnecessary text to make the anwer longer than 4 characters otherwise the forum software rejects it )
Thanks a lot this si a great help. Do you think you can help me with the other question I have posted?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
