What Is the Highest Temperature Reached in the Ideal Gas Cycle?
The discussion revolves around determining the highest temperature reached in an ideal gas cycle involving 7.5 moles of diatomic gas. The user initially miscalculates the temperature using incorrect pressure and volume conversions, confusing pascals with kilopascals. Clarifications emphasize that 3 x 10^4 Pa equals 30 kPa and that the ideal gas constant R can be used in various units. The user is guided to correctly apply the ideal gas law using consistent units to arrive at the correct temperature of 208°C. The conversation concludes with the user expressing gratitude for the assistance, indicating they can now proceed with the problem.
weinbergshaun
Question (see attached diagram):
PV diagram with 7.5 moles of ideal diatomic gas through cycle a, b and c. What is the highest temperature reached by the gas during the cycle? (multiple choice answers 180, 325, 208 and 100 C, i know answer is 208 C but I'm not getting it!) It is a PV diagram with (triangle), pressure is measured in p(PA x 10^4) and volume is V(m^3) The question is on pg 16 at https://www.scribd.com/doc/287176891:
Point a => p = 3 p(PA x 10^4) and v = 0.2 V(m^3)
Point b => p = 5 p(PA x 10^4) and v = 0.6 V(m^3)
Point c => p = 3 p(PA x 10^4) and v = 0.6 V(m^3)
Attempt at question:
Point a:
p = 3 PA x 10^4 (im keeping this and will use R = 8.31 L.KPA/K.mol I THINK PA x 10^4 = kPA!)
V = 600 Litres (converted cubic metres to litres times by 1000)
n = 7,5 (this is given even though its diatomic, it will remain as 7,5 since its moles and not molar mass?
R = 8.31 L.KPA/K.mol T = ? PV = nRT T = PV/Rn T = 3 x 600/8.31 x 7,5
Using T = nR/PV:
T = 1800/62.32 T = 28.8 Kelvin
If i apply this to all the other points then i get nowhere near the 208 C, so this example above shows that one of my values is wrong (and will be wrong for all other points b and c).
Many thanks for your help!
Point a:
No, "kilo" means 1000. 3 x 104 Pa=30 kPa.
Why do you use liters and kPa-s when the volume is given in m3-s and the pressure in pascals? And R=8.31 m3 Pa/(K mol) .
And the problem asks the temperature in °C.
Likes weinbergshaun
Thanks for your assistance. I'm doing the best to figure this out, my books does not give me the laws clearly. So your saying 3 x 10^4 Pa=30 kPa, i was using 3 kPA. I converted cubic meters to liters as i assumed that if you work with pascals you needed to convert the cubic meters to liters and if you work with atmospheric pressure (atm) you work with cubic meters. I also assumed that if you use the kilopascal then you must use R=8.31 and if you just use pascals its the other R = 0,0821 value.
3 x 10^4 Pa=30 kPa, using 3 kPa instead is wrong.
R can be used in different units. See
https://en.wikipedia.org/wiki/Gas_constant.
R=8.31 Pa m3/ (K mol) or R=8.31 kPa L / (K mol) .
Likes weinbergshaun
Ok got it, thanks this helps ten millions times i think i can finish the question now~
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
