What Is the Initial Velocity Required for a Cannonball to Hit a Moving Target?
The discussion focuses on calculating the initial velocity required for a cannonball to hit a moving dog while considering the dog's constant speed of 9 m/s and the cannon's position on a 99 m high cliff. The time for the cannonball to fall to the ground is determined to be approximately 4.49 seconds. The calculations involve separating the vertical and horizontal motions, with the cannonball needing to reach the same horizontal position as the dog when it hits the ground. The final calculation yields an initial velocity of approximately 235.89 m/s for the cannonball. The conversation emphasizes understanding the motion of both the projectile and the moving target to ensure they intersect at the correct time and position.
un_cooled
A cannon which is at the top of a 99 m high cliff fires in a horizontal direction to a dog. The initial position of the dog is 1000 m from the cliff's base. What should be the initial velocity of the cannon if the dog is moving at constant speed of 9 m/s to the cliff.
Other given
square root of (198 m/9.8 m/s) = 4.49 s
Yf = Yi + Vi(t) + (1/2)(gt^2)
Xf = Xi + Vi(t) + (1/2)(gt^2)
For the y-component:
99 m = 0 + Vi(4.49 s) + (1/2)(-9.8 m/s^2)(4.49)^2
= Vi(4.49 s) -99.78 m - 99 m
= Vi(4.49 s) - 198.78 m
For the x-component:
0 m = 1000 m + (-9 m/s)(4.49 s) + (1/2)(-9.8 m/s^2)(4.5)^2
= 860.365 m
Then,
Xi - Xf + Vi(t) + (1/2)(gt^2) = Yi - Yf + Vi(t) + (1/2)(gt^2)
Vi(4.49 s) - 198.78 m = 860.365 m
Vi(4.49 s) = 860.365 + 198.78 m
Vi = 1059.145 m/4.49 s
Vi = 235.89 m/s
Can someone verify this? Thanks alot.
Could you explain what your notations mean? ehild
Yf = final position (y-axis)
Xf = final position (x-axis)
Vi = initial velocity
t = time
g = gravitational pull
Final and initial position of what? There are two moving things: the cannon ball and the dog. They start from different initial positions and they meet, so the final positions are the same for both of them. The ball accelerates downward, but the dog moves with constant velocity.
ehild
actually, I'm not sure about the equations that I used.
There are the Yi and Yf and Xi and Xf data for the ball, and xi and xf for the dog. As it moves on the ground, yi=yf=0. The position of both the ball and the dog are the same when the ball hits the dog, so Yf =0 and Xf=xf. You calculated the time needed to the ball to reach the ground, t=4.49 s. During that time the dog walked some distance, with constant velocity v= 9m/s towrds the cliff. So how far is it from the cliff when the ball hits the ground? The ball has to reach there at the same time as the dog.
You have to know that the motion of a projectile can be treated as two separate motions, one vertical with the downward acceleration -g, the other horizontal with constant velocity Vi. Instead of your equation, Xf=Xi +Vi t. But we measure the distance from the rock, so Xi=0, and Xf is the same as the distance of the dog from the cliff at time 4.49 s. Find Vi.
ehild
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
