MHB What is the last odd digit in the factorial sequence?
  • Thread starter Thread starter ittalo25
    Factorial
The discussion centers on determining the last odd digit in the factorial sequence defined by \( a_n = \frac{(n+9)!}{(n-1)!} \). Participants analyze the composition of \( a_k \), noting that it consists of ten consecutive integers, which include five odd and five even numbers. The key point is that the number of factors of 5 in \( a_k \) exceeds the number of factors of 2, leading to the conclusion that the last non-zero digit is 5. Therefore, the first odd digit after all the zeros in \( a_k \) is ultimately identified as 5. The discussion emphasizes the relationship between the factors of 2 and 5 in determining the last non-zero digit.
ittalo25
Hi guys, my english is very bad but let me try translate the question:
Let $ a_n=\frac{(n+9)!}{(n-1)!} $ . Let k the lesser natural number since that the first digit (on the right side) after all the zeros of $ a_k $ is odd.
Example: $ a_k =$ 4230000000 or $ a_k =$ 62345000
This odd digit number is:
a) 1
b) 3
c) 5
d) 7
e) 9$ a_k = \frac{(k+9)!}{(k-1)!} = k \cdot (k+1)\cdot(k+2)\cdot (k+3)\cdot ... \cdot (k+9) $
We have ten consecutives numbers, which are 5 odds and 5 evens.
By the conditions, we need to have $ a_k = 2^{x}\cdot 5^{y}\cdot... $ with $y \geq x$
But I don't know how continue.
Mathematics news on Phys.org
a) 1
b) 3
c) 5
d) 7
There are more 5's than 2 . after 5's get paired with 2 we get zeros at the end and only od numberer remains along with 5. so last non zero digit is 5.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
