What is the Limit of a Sequence with Infinite Terms?
  • Thread starter Thread starter aid
    Limit Sequence
aid
So, I am to calculate limit of a sequence given by a formula:
\sum^{n}_{i = 1} \sum^{i}_{j = 1} \frac{j}{n^3}
I've tried to write down the sequence explicite and this is what I get:
\frac{1}{n^3} + (\frac{1}{n^3} + \frac{2}{n^3}) + ... + (\frac{1}{n^3} + ... + \frac{n}{n^3})
The last, n-th element could be written as:
\frac{\frac{n(n+1)}{2}}{n^3},
the n-1-th element as:
\frac{\frac{n(n+1)}{2}}{n^3} - \frac{n}{n^3}
and so on. In other words:
\sum^{n}_{i = 1} \sum^{i}_{j = 1} \frac{j}{n^3} = n \frac{n(n+1)}{2n^3} - (n - 1)\frac{n}{n^3} - (n - 2)\frac{n -1}{n^3} - (n -3)\frac{n - 2}{n^3} - ... - \frac{2}{n^3}
If n \rightarrow \infty then the right side of the equation goes to \frac{1}{2}. But the right answer is \frac{1}{6}.
Could anybody tell me what the heck I'm doing wrong?
Your last sentence was
"If n tends to infinity then the right side of the equation goes to 1/2".
Think carefully how are you calculating this limit.
You must take into account that when n tends to infinity, the right side of the equation has an infinite number of terms.
Before calculating the limit, better you try to write the (n-1) last terms in a compact expression.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
