What is the locus of points where $F_x = 1$ and $|F_x| = 2$?
In summary: Good job!In summary, the conversation involved finding the value and unit vector of a vector field $F$ at a specific point $P(-4,3,5)$. The value of $|F|$ was found to be 5.95. The unit vector specifying the direction of $|F|$ at $P$ was calculated to be $0.740a_{x}-0.673a_{z}$. The last question involved finding the locus of points for which $F_x = 1$ and $|F_x| = 2$. The first gives a plane, while the latter gives two lines. The equations for these loci were determined to be $y-2x=2.5$ and
Drain Brain
144
Given the vector field $F=0.4(y-2x)a_{x}-(\frac{200}{x^2+y^2+z^2})a_{z}$ :
1. evaluate $|F|$ at $P(-4,3,5)$;
2. Find unit vector specifying the direction of $|F|$ at P.
3. Describe the locus of all points for which $ F_{x}=1; |F_{x}|=2$
I managed to solve the 1 and 2
By substituting the value of x and y to the vector field I obtain
G
$F=4.4a_{x}-4a{z}$
$|F|=5.95$
$a_{p}=\frac{F}{|F|}=0.740a_{x}-0.673a_{z}$
Can you help me with the last question.
Hi Drain Brain,
What is the meaning of $a_x$ and $a_z$? I'm asking because although $F$ is supposed to be a vector field, the question you seek deals with the equation $F_x = 1$, which is not a vector equation of three dimensions.
Those are the unit vectors in the cartesian coordinate.
Ok, then when you wrote $ F_x = 1$ in part 3, did you mean $|F_x| = 1$?
No. It's just as it is.
So $ F_x $ represents the $ x $- component of $ F $, not the derivative of $ F $ with respect to $ x$?
Yes.
Alright. Then $F_x = 1$ is equivalent to $0.4(y - 2x) = 1$, i.e., $y - 2x = 2.5$. So the locus of points satisfying $F_x = 1$ is the plane $y - 2x = 2.5$. Can you find the locus for $|F_x| = 2$?
Hi euge!
I just want to know what's the difference when we find the locus of points for $F_x = 1$ and $|F_x| = 2$? The absolute value confuses me.
The difference is that the latter gives two lines, whereas the former gives one line. Have you tried working them out?
my answer for $|F|=2$ are
$y-2x=5$ and $y-2x=-5$ are these correct?
They're correct!
FAQ: What is the locus of points where $F_x = 1$ and $|F_x| = 2$?
What is vector analysis?
Vector analysis is a branch of mathematics that deals with the study of vectors, which are quantities that have both magnitude and direction. It involves the use of mathematical operations such as addition, subtraction, and multiplication to manipulate and analyze vectors in different contexts.
What are some real-life applications of vector analysis?
Vector analysis has many practical applications in fields such as physics, engineering, and computer graphics. Some examples include the calculation of forces and velocities in mechanics, the design of electrical circuits, and the creation of 3D computer graphics.
What are the basic operations used in vector analysis?
The basic operations used in vector analysis are addition, subtraction, and scalar multiplication. These operations allow for the manipulation and combination of vectors to solve problems and analyze physical systems.
What is the difference between a vector and a scalar quantity?
A vector is a quantity that has both magnitude and direction, while a scalar quantity only has magnitude. For example, velocity is a vector quantity because it has both speed (magnitude) and direction, while speed is a scalar quantity because it only has magnitude.
How can I visualize vectors in a 2D or 3D space?
Vectors in a 2D space can be represented graphically as arrows, with the length of the arrow representing the magnitude of the vector and the direction of the arrow representing the direction. In a 3D space, vectors can be represented using coordinate axes and the length and direction of the vector can be determined using trigonometric functions.
