What is the magnitude of the charge on each particles
The discussion focuses on calculating the magnitude of charge on two particles with equal and opposite charges, placed 14.8 cm apart. Given the mass of the first particle as 41.0 g and its acceleration of 1.40 m/s², along with the second particle's mass of 54.7 g and acceleration of 1.05 m/s², the relationship between mass and acceleration is emphasized. The formula used, q = sqrt(1/k d² m1 a1), is questioned for accuracy, as the calculated charge of 1.2E-5 C is deemed incorrect. The correct approach involves applying Newton's second law, where m1*a1 equals m2*a2, reflecting the forces acting on both particles. Clarifying the calculations and ensuring the correct application of formulas is essential for accurate results.
shimizua
In the previous problem, what is the magnitude of the charge on each particle?
the previous problem was
Two point-like particles are placed 14.8 cm apart and are given equal and opposite charge. The first particle, of mass 41.0 g, has an initial acceleration of 1.40 m/s2 towards the second particle. What is the mass of the second particle if its initial acceleration towards the first is 1.05 m/s2?
and the answer to that was 54.7g
so i just don't know what I am doing wrong.
so i did this
q= sqrt(1/k d^2m1a1
my answer came to 1.2E-5C but it isn't right. I don't see where I went wrong
You can just right
m1*a1 = m2*a2 because both the charge experience equal and opposite force of attraction.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
