What is the magnitude of the resultant force and angle in this vector problem?
  • Thread starter Thread starter recoil33
    Vector
The discussion revolves around calculating the resultant force and angle from two forces of 26 N and 19 N at an angle of 125°. The initial calculation using the Parallelogram Law yielded an incorrect magnitude due to confusion over the angle used. After clarification, the correct resultant force was determined to be approximately 21.7 N, with an angle of 45.9 degrees from the smaller force. The participants emphasized the importance of accurately identifying the angle opposite the resultant in vector problems. Ultimately, the correct approach involved using the Law of Cosines and the sine rule for angle calculations.
recoil33
Okay, I don't really understand vectors exactly - I think i do, but then i confuse myself.
"Two forces have magnitudes of 26 N and 19 N and the angle between them is 125°. Find the magnitude of the resultant and the angle it makes with the larger of the two forces. Give answers correct to 1 decimal place."
Q1. Resultant Force(N):
Q2. Angle(theta):
Alright, i used the "Parallelogram Law"
Then ended up solving for:
|R2| = 262 + 192 - 2*(26)*(19)*Cos(125)
|R| = (262 + 192 - 2*(26)*(19)*Cos(125))(1/2)
|R| = 40.046
|R| = 40.0N
Although, my answer is wrong. Apparently I've used the wrong angle, something to do with a angle complementary with 180 degrees?
Any help will be appreciated.
(Can't solve Q2 without the answer to Q1) - I should be alright there.
recoil33 said:
Okay, I don't really understand vectors exactly - I think i do, but then i confuse myself...
Your problem is more with trig than vectors. Did you sketch the situation? In the Law of Cosines, angle C has to be opposite the longest side (the diagonal that cuts the 125º in this case).
Use the sketch to see what angle is opposite the diagonal and swap it for 125º in your calculation.
Hmm, I just gave this a shot myself and got the same magnitude for the r vector, it looks correct to me...!
What did you get for the angle?
I get something different.
Converting the forces to vectors and then adding them, we can attempt verify the result. Let...
A = Origin
B = 19N 'point' along the x-axis
C = 26N 'point' in the 2nd quadrant 125deg from the x-axis.
D = Resultant 'point'
We can find their coordinates by using unit-circle equivalencies:
AB = <19cos 0, 19sin 0> = <19,0>
AC = <26cos 125, 26sin 125> ~= <-14.913,21.298>
AB + AC = AD ~= <4.087,21.298> |AD| ~= 21.6866
Angle between AD and the x-axis is arctan 21.298/4.087 = 79.1372deg
So, the final answer = 21.7 N at an angle of 79.1deg from the smaller force-vector.
Is 125deg the proper angle to put into the parallelogram law? I think that is where your approach is not correct. 'Tip to tail' graphing will help find the proper angle using the parallelogram law.
Thanks everyone,
I realized i was using the wrong angle, i think i confused myself with putting the force of 26N 125 degrees away in the other direction. Which should not matter, although it confused myself.
Anyways, I solved it finally.
As for Q2.
I used the sin rule,
a/SinA = b/SinB
19/sin(theta) = |R|/Sin55
= (19Sin55)/21.687 = Sin(x)
= 45.9 Degrees
recoil33 said:
Thanks everyone,
As for Q2.
a/SinA = b/SinB
= 45.9 Degrees
Yep - I just used the x-axis/smaller force for my angle. You'll notice that:
125deg - your answer = my answer (and verifys the correctness)
