What is the mass of a floating block of wood in oil and water?
To determine the mass of a cubical block of wood floating at the interface between oil and water, the block's dimensions and the densities of both fluids are crucial. The block, measuring 10 cm on each side, has its lower surface 2 cm submerged in water, meaning 8 cm is in oil. The relevant formula involves calculating the buoyant force, which equals the weight of the displaced fluids. The confusion arises from the total height of the fluids in the container, but only the submerged volume affects the calculations. Ultimately, the mass of the block can be derived from the buoyant force exerted by the oil and water.
laurenh19
i have a physics problem about buoyancy and could really use some help!
a cubical block of wood 10cm on a side, floats at the interface between oil and water with the lower surface 2cm below the interface. the density of oil is 0.6 g/cm^3 and the density of water is 1.00g/cm^3. what is the mass of the block?
it also has a picture that shows that the container is filled with 10cm of oil on top of 10 cm of water.
force=(density)(volume)(gravity)
i have no idea where to even begin!
If half the volume of the block was below the boundary (5cm below) the block would have a density half way between that of oil and water (i.e 0.8 g/cm^3). From the density you could easily calculate the mass, try using the same argument for the numbers in your question.
i'm confused on why they would say that the container is 10cm full with oil and 10 cm full with water...do i have to add that into my calculations somewhere?
so far I've come up with
mass=(0.6g/cm3)(8cm)+(1.00g/cm3)(2cm)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
