What Is the Maximum Area of a Gothic Window With Given Constraints?
roman15
a gothic window it to be built with 6 segments that total 6m in length. The window must fit inside an area that is 1m wide and 3 meters tall. the triangle on top must be equilateral. What is the maximum area of the window.
so i made each of the sides of the trianle x and the width at the bottom of the rectangle x, then the sides of the rectangle equal to y. so the perimeter is 6=4x+2y
and the area A=1/2xh + xy
the height of the triangle would be 3-y wouldn't it? because then i plugged that in for h, and then isolated for y in the perimeter equation and plugged in y where it was necessary but i didnt get the right answer in the end after i got the derivative
No, you don't know h=3-y. Given your perimeter constraint the maximum area window might not touch all sides of the 1m by 3m area. All you really know is that x<=1 and y+h<=3. What is true that h is related to x just because x is the side of an equilateral triangle and h is the height.
I'm assuming your shape is like this?
Code:
[u]/\[/u]
|_|
Since the top has to be an equilateral triangle you know that 3 segments have to be equal (if the base of the triangle counts as a segment). Then you have 3 segments left over to play with (the sides below the triangle and the base of the window)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
