MHB What Is the Maximum Area of This Isosceles Trapezoid?
The maximum area of the isosceles trapezoid with a shorter base of 8 units and a slant height of 12 units is approximately 146.345 square units. This maximum occurs when the variable \( x \) is approximately 6.7178 units. The area can be expressed as a function \( A(x) = 8\sqrt{12^2-x^2}+x\sqrt{12^2-x^2} \), which is maximized through calculus methods. The exact area can also be represented using the formula \(\left( 2\,\sqrt{19}+6\right) \,\sqrt{8\,\sqrt{19}+64}\). The problem illustrates a constrained maximization scenario within specified boundaries.
checkitagain
Given:
an isosceles trapezoid
The shorter base is 8 units in length
The slant height is 12 units in length.What is the maximum area that this isosceles trapezoid could have?
You could answer with either an exact number, or an answer
where the value is to the nearest hundredths of square units,
if the exact value is "too cumbersome."
Mathematics news on Phys.org
checkittwice said:
Given:
Let the other base be of length \(8+2x\), then the area is:
\[ A(x)=8\sqrt{12^2-x^2}+x\sqrt{12^2-x^2} \]
subject to the constraints that \( x \in [0,12] \).
This is a constrained maximisation problem, so the maximum occurs at a calculus type local maxima of \(A(x)\) in the interior of the feasible region or at a boundary point.
The maximum area is \(\approx 146.345 \) square units and occurs when \( x=2(-1+\sqrt{19} ) \approx 6.7178 \) units
Exact area (courtesy of Maxima): \(\left( 2\,\sqrt{19}+6\right) \,\sqrt{8\,\sqrt{19}+64}\)
(note: copy and past of LaTeX from Maxima works perfectly)
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
