What Is the Maximum Bending Moment in a Loaded Beam?
In summary, the problem involves a simply supported beam with specific dimensions and loads. The goal is to find the maximum bending moment and its distance from the origin. The approach typically involves creating shear and moment diagrams, accounting for point loads. The solution yields a maximum bending moment of 275.10 kNm at a distance of 3.42 m from support A.
warrio1010
A beam ABCD simply supported at A and C. AB= 2 m, BC= 6 m, AC=8m and CD= 2 m. It carries a uniformly distributed load of 30 kN/m between A and C and concentrated loads of 50 kN and 20 kN at B and D respectively.
I want to find the maximum bending moment and its distance from the origin.
I have tried M=(wx/2)*(L-x) but don't think this is right.
The answer is 275.10 kNm, 3.42 m from support A.
Thanks
Well these problems are usually attacked by starting with Shear Diagrams, then moment diagrams, also known as shear and moment diagrams.
Of course do not forget to account for discontinuous point loads.
Related to What Is the Maximum Bending Moment in a Loaded Beam?
1. What is the definition of maximum bending moment in mechanics?
The maximum bending moment in mechanics is the greatest internal moment of force within a structure due to an external load. It occurs at the point where the structure experiences the most stress and is a critical factor in determining the strength and stability of the structure.
2. How is the maximum bending moment calculated?
The maximum bending moment is calculated by multiplying the external load by the distance from the load to the point of interest, also known as the bending moment arm. This calculation takes into account the type of load, the shape of the structure, and the material properties.
3. What are the units of maximum bending moment?
The units of maximum bending moment are typically expressed in Newton-meters (Nm) or foot-pounds (ft-lb) in the metric and imperial systems, respectively. These units represent the amount of force and distance involved in the bending moment calculation.
4. How does the maximum bending moment affect the design of a structure?
The maximum bending moment is a critical factor in determining the strength and stability of a structure. It is used to calculate the required size and shape of structural elements, such as beams and columns, to ensure they can withstand the maximum load without breaking or buckling. Designers must consider the maximum bending moment when creating safe and efficient structures.
5. Can the maximum bending moment change over time?
Yes, the maximum bending moment can change over time due to different external loads or structural changes. It can also vary along the length of a structure, depending on the distribution of the load. In dynamic systems, the maximum bending moment may also vary with time as the external load changes.
