What is the maximum energy of the Λ particle after the Σ0 baryon decay?
The discussion centers on the decay of a Σ0 baryon into a Λ particle and a photon, with a focus on determining the maximum energy of the Λ particle post-decay. The maximum energy condition occurs when the Λ and photon move in opposite directions, conserving momentum and energy. The calculations involve using conservation laws and relativistic equations to derive the energy of the Λ particle in both the rest frame of the Σ0 baryon and the lab frame. Participants clarify the importance of correctly applying relativistic transformations to find the Λ's velocity and energy in the lab frame, emphasizing the need for accurate configuration understanding. Ultimately, the discussion highlights the complexities of particle decay and energy calculations in relativistic physics.
ElectricEel1
A Σ0 baryon, traveling with an energy of 2 GeV, decays electromagnetically into a Λ and a photon.
What condition results in the Λ carrying the maximum possible energy after the decay? Sketch how the decay appears in this case, and calculate this energy. Explain your reasoning.
[Mass of Σ0 is 1.193 GeV/c2; mass of Λ is 1.116 GeV/c2]
E^2 = m^2 + p^2
in the rest frame of the sigma baryon, E_sigma = m_sigma
p_lambda = - p_photon
E^2_lambda = m^2_lambda + p^2 lambda
E_photon = modulus of p photon.
im trying to start by solving for the energy of the lambda particle in the rest frame of the sigma baryon but I am stuck. so far i have
E_lam = E_sig - E_photon
In the rest frame, you have energy and momentum of lambda and photon as unknowns, but you have conservation of energy, conservation of momentum and the energy/mass/momentum relation (separately for photon and lambda) - four equations for four unknowns, and you wrote down the four equations already. Plug the equations into each other until you can solve for a single variable.
thanks. so my four equations are
E_sig = m_sig
E^2_photon = modulus p^2_photon
E^2_lamb = m^2_lamb + p^2_lamb
p_lamb = - p_photon
The first one should be replaced by conservation of energy. The decay products have the same total energy as the original particle.
so if E_sig^2 = E_lam^2 + p_photon^2 = E_lam^2 + p_lamb^2 then since p_lamb^2 = E^2_lamb - m^2_lamb then i can plug that into the equation to get rid of the momentum which gives me
E^2_lambda = (E^2_sig + m^2_lamb)/2 = 1.155 Gev?
is this the condition of maximum energy where they go in opposite directions
This is the energy of the lambda in the sigma rest frame. In that frame the decay products always go in opposite directions. What leads to the maximal energy of the lambda in the lab frame, where the sigma is moving?
in the frame where the sigma is moving could I have it so the lambda takes all the momentum and the photon is at rest i.e doesn't exist?
No, that doesn't work, as you calculated already: the lambda has an energy of 1.155 GeV, which is not identical to 1.193 GeV.
Not having a photon would violate energy-momentum-conservation.
im still a little lost with it but in the lab frame the energy of the sigma particle is 2.0Gev so i'll need to use this i guess. could they go the same way? it hasnt yet made sense what makes the sigma energy maximum. The photon is massless so the energy of that will just be the momentum.
Why? They didn't ask this. What do they ask?
Think about the directions the particles can go to.
This is similar to a classical mechanics problem with a rocket: a rocket (sigma) is flying to the right. It fires its engines (it emits a photon). In which direction should it fire to maximize its speed afterwards?
to be honest there was another thread on this subject and they said to start from there so that's where i started.
it should fire the photon to the right
"Its speed" refers to the rocket (sigma->lambda). If you fire something to the right you slow down the rocket.
oh i get you now. so the photon would fly out to the left and the lambda would continue right? but in this case they have different momenta?
so to switch to the moving frame i found the lambda velocity to be 0.034c and doing the velocity equation i calculated that that means the lab frame is moving at 0.034c. I am not sure if this was the right step to make
Did they ask for this? What did they ask for?
The velocity didn't change when you switched between frames?
@Vanadium 50: Where is your point? Calculating the velocity in the sigma rest frame is a perfectly valid intermediate step.
He hasn't yet answered the question of the configuration resulting in the maximum energy. Until's he's got this, he shouldn't go calculating things willy-nilly. Yes, they might be useful - but they might not.
they asked for the configuration which gives the lambda maximum energy and to calculate the energy.
no, i got the velocity using the relativistic momentum equation then tried to use u' = (u-v)/(1-(uv/c^2)) to switch to the other frame but since its the rest frame i used u=0 so it just canceled to v
The other frame is the lab, where the sigma is moving.
@V 50: I think your questions are more distracting than helpful in this case.
realised i did the above part wrong. I found the velocity of the sigma in the lab frame using the 2Gev energy given in the question then used that to transform from rest frame to that frame and got lambda velocity as 0.7c then found momentum as 1.085gev/c and energy 1.56Gev but maybe vanadium is right. Have I got the right idea about the configuration and have I gone about this the right way?
If you understood the rocket part, you can add the velocities to get the speed of the lambda.
i understood the idea of the rocket part but I've been trying to use a transform to get from the speed in the sigma rest frame and got 0.7c for the speed of the lambda in the lab frame then got the energy from the momentum. i think that's the point I am missing. which velocities am i adding together?
The sigma moves relative to the lab, the lambda moves relative to the sigma. And you get the largest lambda velocity in the lab if ...
It the lambda keeps moving forward relative to the sigma and the lambda moves backwards? The speeds of the photon and sigma are c and 0.69c
Why do you expect the lambda to move backwards now?
The lambda forwards and photon backward sorry
Awesome. So I already calculated the energy and now I have the configuration too? Thanks
I don't see where you got the right final answer. It got scattered across posts a bit.
  • #31
i had 0.034c as the velocity of the lambda in the sigma rest frame. then using 2gev as the energy of the sigma in the lab frame, I calculated the momentum and used the relativistic momentum equation to find the sigma velocity. Then I used u' = (u-v)/(1-uv/c^2) to where u = 0.034c and v = 0.69c (sigma velocity in lab frame) to get the lambda velocity and then the energy. Or should I have used u = (u' + v)/(1 + u'v/c^2) since I am transforming from a rest frame to the actual lab frame
  • #32
One will lead to a value that doesn't make sense, the other one is the right answer.
