What is the minimum value of a trigonometric expression with a given condition?
A)+\cot^2(B)+\cot^2(C)\geq 1and equality hold when A=B=C=\frac{\pi}{3}When we use \mathbb{A.M}\geq \mathbb{G.M} That's why I am saying that the summary is not correct. Please check the conversation and summary again.
juantheron
247
If $A+B+C=\pi$. Then Minimum value of $\cot^2(A)+\cot^2(B)+\cos^2(C)$ is
What have you tried?
If you put \(C=\pi-(A+B) \) and substitute into the objective you get an unconstrained optimisation problem in two variables.
CB
Thanks Caption Black But I did not Understand What steps i do after that means after converting into 2 variable.
would you like to explain it to meWe Know that If [tex]A+B+C = \pi[/tex], Then [tex]\tan (A)+\tan(B)+\tan(C) = \tan(A).\tan(B).\tan(C)[/tex]Which we can prove easily[tex]A+B=\pi-C\Leftrightarrow \tan(A+B) = \tan (\pi-C) = -\tan (C)[/tex]So [tex]\frac{\tan(A)+\tan(B)}{1-\tan(A).\tan(B)} = -\tan (C)[/tex]So [tex]\tan (A)+\tan(B)+\tan(C) = \tan(A).\tan(B).\tan(C)[/tex]Now Using [tex]\mathbb{A.M}\geq \mathbb{G.M}[/tex][tex]\frac{\tan (A)+\tan(B)+\tan(C) }{3}\geq \left(\tan(A).\tan(B).\tan(C)\right)^{\frac{1}{3}}[/tex][tex]\frac{\tan(A).\tan(B).\tan(C)}{3}\geq \left(\tan(A).\tan(B).\tan(C)\right)^{\frac{1}{3}}[/tex][tex]\left(\tan(A).\tan(B).\tan(C)\right)^3\geq 27 \left(\tan(A).\tan(B).\tan(C)\right)[/tex]So [tex]\left(\tan(A).\tan(B).\tan(C)\right)\geq 3\sqrt{3}[/tex]bcz [tex]\tan(A).\tan(B).\tan(C)> 0[/tex]So [tex]\cot(A).\cot(B).\cot(C)\leq \frac{1}{3\sqrt{3}}[/tex]Now again Using [tex]\mathbb{A.M}\geq \mathbb{G.M}[/tex][tex]\frac{\cot^2(A)+\cot^2(B)+\cot^2(C)}{3}\geq \left(\cot(A).\cot(B).\cot(C)\right)^{\frac{2}{3}}[/tex]So [tex]\cot^2(A)+\cot^2(B)+\cot^2(C)\geq 1[/tex]and equality hold when [tex]A=B=C=\frac{\pi}{3}[/tex]
This is a different question from the one you asked in the original post. Please clarify what the question really is.
Also as this is posted in the calculus area of MHB I would expect to see some calculus.
CB
By the way equality holds when \( \cot^2(A)=\cot^2(B)=\cot^2(C) \) which does not imply that \(A=B=C \) unless you place some restriction on the allowed values of \(A,B\) and \(C\), which you have not done.
CB
Given a function \(f(x,y,z)\) for which you seek a minimum subject to a constraint \(z=g(x,y)\), we look for the unconstrained minimum of \(h(x,y)=f(x,y,g(x,y))\).
Such a minimum if it exists is a solution of:
\[ \begin{aligned} \frac{\partial}{\partial x}h(x,y)=0 \\ \frac{\partial}{\partial y}h(x,y)=0 \end{aligned} \]
Applying this to the given problem of minimising \(f(A,B,C)= \cot^2(A)+\cot^2(B)+\cot^2(C)\) subject to \(A+B+C=\pi\) , gives us a condition:
\[\frac{\cos(A)}{\sin^3(A)}=\frac{\cos(B)}{\sin^3(B)}=\frac{\cos(C)}{\sin^3(C)}\]
and as \( \cos(x)/\sin^3(x) \) strictly decreasing over \((0,\pi)\) and periodic with period \( \pi \) this implies that \( B=A+n\pi,\ C=A+m\pi ,\ n,m \in \mathbb{Z}\). So:
\[ A=\frac{\pi(1-n-m)}{3} \]
(Not all of these critical point correspond to minima, in particular the cases where \(1-n-m\) is a multiple of \(3\) are not)
Now since \( \cot^2(x) \) is periodic with period \(\pi\) at a critical point we have:
\[f(A,B,C)= \cot^2(A)+\cot^2(B)+\cot^2(C)=3\;\cot^2(A)=3\;\cot^2\left( \frac{\pi(1-n-m)}{3} \right)\]
and a bit more checking shows that the mimimum is \(1\) and occurs whenever \(1-n-m\) is not a multiple of \(3\).
Note: if we had specified that \(0\le A,B,C \le \pi\) at the start we would have found that the critical point is \(A=B=C=\pi/3\) without much trouble.
CB
CB
Yes CaptionBlack
FAQ: What is the minimum value of a trigonometric expression with a given condition?
What is a trig minimum?
A trig minimum is the lowest point on a trigonometric function. It is the point where the function reaches its smallest value.
How do you find the minimum of a trig function?
To find the minimum of a trig function, you can use calculus techniques such as finding the derivative and setting it equal to 0, or using the first or second derivative test.
What is the significance of a trig minimum?
The trig minimum can tell us important information about the function, such as the range and the behavior of the function near the minimum point.
Can a trig minimum be negative?
Yes, a trig minimum can be negative. It depends on the specific function and its range.
Are there any shortcuts for finding a trig minimum?
There are no shortcuts for finding a trig minimum, but there are certain patterns and strategies that can make the process easier, such as using symmetry or graphing the function to visually estimate the minimum point.
