MHB What is the minimum value of $n$ for a nonnegative polynomial with degree $d$?
  • Thread starter Thread starter melese
    Polynomials
A polynomial with real coefficients that takes only nonnegative values can be expressed as a sum of squares of other polynomials. The discussion centers on determining the minimum integer value of \( n \) for a nonnegative polynomial of degree \( d \). Examples provided indicate that \( n = 2 \) for \( d = 2 \) and \( n = 1 \) for \( d = 0 \). The method involves using linear algebra concepts to construct polynomials that satisfy the conditions. This topic is also linked to Hilbert's seventeenth problem, which addresses similar polynomial representations.
melese
(HUN,1979) Prove the following statement: If a polynomial $f(x)$ with real coefficients takes only nonnegative values, then there exists a positive integer $n$ and polynomials $g_1(x),g_2(x),...,g_n(x)$ such that $f(x)=g_1(x)^2+g_2(x)^2+\cdots+g_n(x)^2$.
A related question of my own, but I don't have/know the answer:
If $\deg({f})=d$, then what is the smallest possible value of $n$.
For example: I know that it's $2$, when $d=2$ and $1$ when $d=0$.
መለሰ
Mathematics news on Phys.org
መለሰ
I thought of this in terms of linear algebra and vector spaces. Consider the set
\begin{matrix}
g_0(x)=\sqrt{c_0} & g_0^2(x)=c_0 \\
g_1(x)=(1+c_1x) & g_1^2(x)=1+2c_1x+c_1^2x^2\\
g_2(x)=\sqrt{c_2}x & g_2(x)=c_1x^2\\
g_3(x)=(x+\sqrt{c_3}x^2) & g_3(x)=x^2+c_3x^3+c_3^2x^4\\
g_4(x)=\sqrt{c_4}x^2) & g_4(x)=c_4x^4 \\
g_5(x)=(x^2+\sqrt{c_5}x^3 & g_5(x)=x^4+c_5x^5+c_5^2x^6 \\
\vdots & \vdots \\
\end{matrix}
This gives a matrix that looks like this
\begin{bmatrix}
c_0 & 0 & 0 & 0 & 0 & \dots \\
1 & 2c_1 & c_1^2 &0 & 0 & \dots \\
0 & 0 & c_2 & 0 & 0 & \dots \\
0 & 0& 1 & 2c_3 & c_3^2 & \dots \\
\vdots &\vdots &\vdots &\vdots &\vdots & \ddots \\
\end{bmatrix}
As long as the number of rows $$ k$$ is odd the set will be linearly independant and thus span polynomial space of degree $$k-1$$
Just to be clear now we can pick [math]c_0,c_1,c_2,...[/math] so that we can get any polynomail
For example if $$f(x)=3x^2-8x+10$$, then
We solve
\begin{matrix}
c_0+1=10 \\
2c_1=-8 \\
c_1^2+c_2=3
\end{matrix}
This gives
$$c_0=9, \quad c_1=-4, \quad c_2=-13$$
and $$9g_0^2-4g_1^2-13g_2=9+1+2(-4)x+(-4)^2x-13x^2=3x^2-8x+10$$
I think this will help settle your other question as well.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
