What Is the Molecular Formula of the Alkane in This Chemistry Problem?
  • Thread starter Thread starter daphap
The discussion revolves around determining the molecular formula of an alkane based on a chemistry problem involving combustion and gas volume changes. The empirical formula C2H5 has been proposed, and the user seeks guidance on how to derive the molecular formula from this. It is emphasized that understanding the bonding requirements of carbon atoms in alkanes is crucial, as each carbon needs four bonds. By applying the relationships between the number of carbons and hydrogens derived from the empirical formula, the user can calculate the precise molecular formula. This approach is essential for solving similar chemistry problems effectively.
daphap
Eurgh, for some reason I can't get my head around this chemistry homework!
"When 20cm^3 of this alkane were burnt in 200 cm^3 of oxygen (an excess), the residual gases occupied 150cm^3. On shaking with an aqueous potassium hydroxide, this volume decreased to 70 cm^3. (All at rtp and pressure). What is the molecular formula of the alkane."
Oh yeah, and I devised that the empirical formula of th alkane was C2H5.
I am aware I have to show my work to get help... but I really don't know where to start. If someone good guide me through a similar problem with alter numbers I would greaty appreciated. Thanks.
How did you devise the empirical formula of the alkane was C_2 H_5?
If you're sure this is the right empirical formula, then you're basically done.
You now have to know a bit about alkanes.
An alkane is a chain of single-bonded carbons with enough hydrogens attached to each carbon. Knowing that each carbon needs fours bonds to be "happy", you can find a relationship between the number of carbons in an alkane and the number of hydrogens.
You now use the empirical formula, which also gives you another relationship between the number of carbons and hydrogens present in your alkane. With those two formulas in hand, you can figure out precisely how many carbons and hydrogens a molecule of your alkane is made up of.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
