What is the Moment of Inertia of a Flywheel?
The discussion focuses on calculating the moment of inertia of a flywheel given that it accelerates from rest to an angular speed of 14.5 revolutions per second with a work input of 22.0 kJ. The relevant equation used is ½Iω² = 22.0 kJ, leading to the rearrangement I = (2)(22.0 kJ)/ω². The angular speed is converted to radians per second, resulting in ω = 29π rad/sec. After performing the calculations, the moment of inertia is determined to be approximately 0.00531 kg·m². The discussion also highlights the importance of using SI units correctly, specifically converting 22 kJ to joules.
deltas
The work done in accelerating a flywheel from rest to an angular speed of 14.5 revolutions per second is 22.0 kJ. What is the moment of inertia of the flywheel?
½Iω² = 22.0 kJ
½Iω² = 22.0 kJ
I = (2)(22.0 kJ)/ω²
ω = (14.5 revs/sec)
= (14.5 revs/sec) × (2π rad/rev)
= 29π = 91.1
I = (2)(22)/(91.1)2
I = 44/8300.3
I = 0.00531
You are using SI units. How many joules are there in 22kJ?
Oh, thank you! I hadn't even noticed!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
