What Is the Momentum of an Electron in Muon Decay?
The discussion focuses on calculating the momentum of an electron produced from muon decay, with the muon at rest and initial momentum set to zero. Participants emphasize the importance of conservation of momentum and energy, noting that the momentum of the electron equals that of the photon. They explore various equations, including those for relativistic energy and momentum, while clarifying the distinction between the gamma factor and the photon energy. The conversation highlights that the energy is approximately split evenly between the electron and photon due to the relativistic nature of the electron. Ultimately, the key takeaway is the application of conservation laws and relevant equations to solve for the electron's momentum.
tib
Unstable, subatomic particles called muons have a rest energy of 105.7 MeV and a speed of 0.994c. If a muon were to decay and produce an electron and a photon, what would be the momentum of the electron as measured by an observer in the muon's frame? HINT: assume that the electro goes in the +x direction, the photon goes in the -x direction, and the muon is at rest in its own frame.
E = mc^2 + K; p = gamma*m*v; numerous other forms of relativistic energy equations
By the hint, (muon is at rest) we can assume that the initial momentum is zero. By conservation of momentum, initial momentum = final momentum thus, momentum of the electron = momentum of the photon.
This is as far as I can get. The posted answer is 52.8 MeV/c.
You need to conserve total energy as well.
Do you know how to use four-vectors?
i do not know how to use four-vectors
OK, no problem. So far you have
0 = pe-pγ
What equation do you get from conservation of energy?
EDIT: Some advice: write it in terms of Ee, Eγ, and any relevant masses.
Also, the subscript γ is meant to label the energy and momentum of the photon; it's not the gamma that shows up in the relativity equations.
if we treat the muon at rest, Ei=Emuon=Eo=105.7 MeV
Ef=Ee+Eγ
I know Eγ=hf, but I feel like that's going in the wrong direction for the problem; also I know Ee=γmec2, but without the Eγ, I feel that's a deadend as well.
Right. I'd just write it as Ei=mμc2. It's easier to plug the numbers in at the end.
Ef=Ee+Eγ
Yeah, generally, you want to solve for energies and momenta directly. Throwing in things like gamma, velocity, and frequency just complicate the algebra.
One of the most useful relations you have for these types of problems is
(mc^2)^2 = E^2 - (pc)^2
So the idea is to rearrange the terms in the equations slightly, then square both equations, subtract one from the other, and use this relation to simplify the result.
I can see where I (think) I should go, by the equation you gave and by knowing the actual answer, I can see I find p=E/2c. If this is correct, we know by conservation of momentum that pe=pgamma; how do we know that the energy of the muon is split equally between the electron and photon?
Additionally, I still don't see the math to get to p=E/2c; using (mc2)2=E2-(pc)2 for the Ei; the result is 0=-(pc)2, because E=Eo=mc2 -- which does make sense, but isn't useful
And for Ef, photons are massless, but have momentum, so I don't see how to apply that equation to Ef.
The energy isn't split evenly between the electron and photon.
The relation (mc2)2=E2-(pc)2 is good for each particle, so for the electron, you'd have (mec2)2=Ee2-(pec)2. The photon has no rest mass, so the relation reduces to 0=Eγ2-(pγc)2, or Eγ=|pγ|c.
It is easy to learn.
Also, note that the energy is split approximately evenly between the photon and electron, as a result of the electron being extremely relativistic.
