What is the near-point of the eye-plus-spectacle?
  • Thread starter Thread starter gungo
The discussion centers on calculating the near point of the eye with spectacles, specifically addressing the power needed for a near point of 0.75 m. A participant calculated the eye's power using the formula P = 1/.25 m + 1/-.75 m, resulting in a power of 2.67 diopters. They then added this to the lens power of 0.75 diopters but encountered confusion when the expected near point was 48 cm instead of their calculated -1.72 m. The conversation highlights the importance of understanding the near point of a normal eye, which is typically 0.25 m, equating to a power of 4 diopters, but this exercise involves a different eye configuration.
gungo
A hyperopic eye has a near point of 75 cm. If a lens of power .75 d is placed in front of the eye, what is the near point of the eye-plus spectacle?
P= 1/p + 1/q
I found the power of the eye itself by doing P= 1/.25 m + 1/ -.75 m. I used negative .75 m because the image would be on the same side of the object. I got a power of 2.67 d. The I added that to the .75 d of the lens. Then I used the same equation and did 3.42= 1/.25 m +1/q to find q, and got -1.72 m. However, the answer is 48 cm.
Hi,
Where does the 0.25 come from?
What power is really needed for a near point of 0.75 m ?
BvU said:
Hi,
I learned in class that 0.25 m was the near point of a normal eye
So a normal eye has a power of 4 d. But:
This exercise is about a different eye ! Namely, with a power of ...
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
