What Is the Normal Stress in a Prismatic Bar Under Tension?
To find the normal stress in a prismatic bar under tension, the formula used is stress equals force divided by area. In this case, a force of 100 N is applied to a bar with a cross-sectional area of 5 cm². The correct calculation involves converting the area to m², resulting in a stress of 20,000 Pa or 20 kPa. Confusion arose regarding unit conversions and whether the force should be doubled if the bar is supported in the middle. Clarification on the derived units of Pascal confirms they are indeed N/m².
Baumer8993
In a prismatic bar (same cross sectional area throughout the entire length), the load applied to both ends is 100 N causing the member to be in tension. If the cross sectional area of the member is
5 cm2. What is the normal stress in the in kPa?
stress = force / area
I first tried without looking at the units, and got 20, which is wrong. I next tried converting everything to m2 to get the answer is pascals the convert to kPa. I got 200 for my second answer. What am I doing wrong? This seems like such a simple problem!
What are the derived units of a Pascal? Are they N/m^2 or N/cm^2?
They are N/m^2. I used an online converter to check, so I confused about what I did wrong.
Is the bar supported in the middle? If so, should the force be 100 or 200 N?
How did you get 20?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
