What Is the Optimal Launch Angle for Maximum Distance?
  • Thread starter Thread starter Curious-T
    Angle Launch
The optimal launch angle for maximum distance when projecting an object from a height of 2 feet is less than 45 degrees, contrary to the common belief that 45 degrees is ideal for ground-level launches. Calculations indicate that at a launch speed of 8.05 ft/second, the distance achieved at 45 degrees is 3.24 feet, while the optimal angle of approximately 30 degrees yields a distance of 3.46 feet. The launch angle's effectiveness is influenced by the initial height and speed, requiring a more complex analysis than simply applying the 45-degree rule. The trajectory equations reveal that the optimal angle must be derived from the relationship between time of flight and horizontal distance. Thus, determining the optimal launch angle involves solving intricate equations based on the object's initial conditions and the ground profile.
Curious-T
I would like to know what the Optimum Angle of Launch would be for an object projecting forward to obtain maximum distance.
The object will be traveling approximately 25 mph and will launch off a surface 2 feet above the ground.
What is the Optimum Angle of Launch to get that object to the farthest point on the ground?
Thanks for any help...
I was told that 45 degrees is optimum on a level horizontal plane. In other words the if the object was projected from ground.
However, in this case the object is projected from 2 feet above the ground.
Does that make a difference?
I believe in this case the angle is slightly less than 45 degrees.
you can work it out by brute forcing. find the time it takes to land, then substitute t in the x equation, then differentiate to find maximum R.
The optimal angle is indeed less than 45 degrees if the object starts its trajectory above the ground. An example: Suppose the object is thrown 2 feet above the ground with an initial speed of 8 .05 ft/second. A 45 degree angle results in the object going 3.24 feet. The distance is 3.46 feet at the optimal angle of 30 degrees.
This looks like homework. The original poster should show some work.
The optimal launch angle does, indeed, depend on the launching position and the ground profile.
Assume that the initial vertical position, launch speed, launch angle, ground profile is y_{0}, v, \theta, h(x) respectively.
Then, as a function of time, the object's vertical and horizontal positions (starting at x=0) are
y(t)=y_{0}+(v\sin\theta){t}+\frac{gt^{2}}{2}, x(t)=(v\cos\theta){t}
The object hits the ground at some time T when y(T)=h(x(T)), that is we gain the ground state equation:
h((v\cos\theta)T)=y_{0}+(v\sin\theta)T+\frac{gT^{2}}{2}
an equation by which we in principle can solve for the collision instant T as a function of \theta, called T(\theta)
The RANGE is therefore the horizontal coordinate considered as a function of the launch angle:
x(\theta)=v\cos\theta{T}(\theta)
and the optimal launch angle \theta_{op} is determined by solving the the algebraic equation \frac{dx}{d\theta}=0, that is finding the solutions of:
-(\sin\theta_{op})T(\theta_{op})+(\cos\theta_{op})\frac{dT}{d\theta}\mid_{(\theta=\theta_{op})}=0\to\frac{1}{T(\theta_{op})}\frac{dT}{d\theta}\mid_{(\theta=\theta_{op})}=\tan(\theta_{op})
In the general case, it is by no means a trivial matter to determine the function T(\theta), nor is it trivial to solve the range equation for \theta_{op}
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
