MHB What is the Perimeter of Triangle ABC?
To find the perimeter of Triangle ABC with vertices A(1, 1), B(9, 3), and C(3, 5), the distances between each pair of vertices must be calculated. The distances AB, BC, and AC are determined using the distance formula. After calculating these distances, they are summed to obtain the perimeter of the triangle. The discussion confirms that this method is correct for finding the perimeter. The process is straightforward and emphasizes the importance of accurate distance calculations.
mathdad
The vertices of Triangle ABC are A(1, 1), B(9, 3), and
C(3, 5). Find the perimeter of Triangle ABC.
I need to find the distance of AB, BC, and AC. I then must add all three distances to find the perimeter.
Correct?
Mathematics news on Phys.org
Correct?
Yes.
Evgeny.Makarov said:
Yes.
Feels good to be right.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
