MHB What is the Probability of Rolling a Number 6 Four Times in a Row on a Dice?
The discussion revolves around calculating the probability of rolling a six four times in a row on a die, given that a six appeared 14 times in 100 rolls. The method proposed involves determining the total arrangements of rolling a six 14 times and then finding the arrangements where six is rolled four consecutive times. The probability formula provided is based on the binomial distribution, assuming a fair die with a probability of one-sixth for rolling a six. However, some participants raise concerns about the clarity of the question, questioning whether it pertains to a single run of four sixes or multiple runs. Overall, the conversation emphasizes the need for precise definitions in probability calculations.
Essential06
Can anyone help me with this one please...
If i roll a dice 100 times and number 6 comes out on 14 occassions (14%) what would have been the probability of number 6 being rolled 4 times in a row? (as a percentage?)
If someone would be so kind to tell me how to calculate this in simple terms i'd be really grateful. Thanks
Mathematics news on Phys.org
Re: Probability Help Please
If i roll a dice 100 times and number 6 comes out on 14 occasions (14%) what would have been the probability of number 6 being rolled 4 times in a row? (as a percentage?)
Hi Essential06, :)
Let me summarize the method that I will use to solve this problem.
Find the number of arrangements with 6 rolling out on 14 occasions(we shall take this as \(x\)). Then among those outcomes with 14 sixes find the number of arrangements where 6 is rolled 4 times in a row(we shall take this as \(y\)). Supposing that each outcome with 6 being rolled 4 times in a row is equally likely to happen,
The probability of getting 6 rolled 4 times in a row is, \(\dfrac{y}{x}\).
Hope you can continue.
Kind Regards,
Sudharaka.
If p is the probability of the number six in each roll, then the probability to have 4 six in 10 rolls is,,,
$\displaystyle P= \binom {10}{4} p^{4}\ (1-p)^{6}$ (1)
If the dice is 'non loaded' then is $\displaystyle p=\frac{1}{6} = .16666666666...$ and that is compatible with 14 six in 100 rolls. If $\displaystyle p=\frac{1}{6}$ then the (1) gives $\displaystyle P= .05426587585...$...
Kind regards
$\chi$ $\sigma$
I for one would like you to explain exactly what this question means.
Are you asking about exactly one run of four 6's?
Or could there be three runs of four 6's.? If so do they have to be separated?
If not how do you count a run of six 6's?
This question is so ill-defined as to be unanswerable.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
