MHB What is the proof for angle equality?
  • Thread starter Thread starter paulmdrdo1
    Angle Proof
When two lines intersect, they create opposite angles that are equal due to the properties of vertical angles. This relationship is grounded in the theorem stating that angles formed by intersecting lines are equal when their sides are perpendicular. The proof of angle equality can be derived from this theorem, demonstrating both the "how" and "why" of their equality. Understanding this fundamental concept is essential in geometry. The discussion highlights the importance of recognizing the properties of intersecting lines in proving angle relationships.
paulmdrdo1
382
I've been searching over the internet and geometry books for the proof of the relationship of these two angles but I couldn't find one. Can you tell me the "how" and "why" of their equality. thanks and regards!
Mathematics news on Phys.org
Use the fact that when two lines intersect, opposite angles are equal. The result then follows.
Check post #5.
http://mathhelpboards.com/trigonometry-12/equality-angles-11593.html
"There is a theorem saying that two angles whose sides are mutually perpendicular are equal. "
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
