What is the ratio of t to r in a set of equations involving p, q, r, s, and t?
  • Thread starter Thread starter bluepillow
    Ratio
The discussion revolves around finding the ratio of t to r from a set of equations involving variables p, q, r, s, and t. The user expresses difficulty in simplifying the equations and seeks guidance on how to eliminate variables effectively. Suggestions include rearranging the equations and substituting t with a new variable, a, to simplify calculations. Additionally, there are tips on using LaTeX for formatting equations correctly in posts. The conversation emphasizes collaboration and sharing techniques to solve the mathematical problem.
bluepillow
Hey guys, I joined after struggling with a few problems for the past two days. I feel as if the answers are blantanly obvious and I'm just missing the simplest and most important bit(s).
From the set of equations:
p=3q
pr=qs
(1/2)pr2 + (1/2)qs2 = (1/2)qt2
involving the unknowns p, q, r, s, and t, find the value of the ratio t to r.
above
The first thing I did was rearrange the top two equations so I can eliminate certain variables from the 3rd equation.
My possible rearrangements are:
p=3q
p=(qs)/r
q=p/3
q=(pr)/s
r=(qs)/p
s=(pr)/q
After a few trial and error replacements I keep getting complicated equations that are going to take a while to type out. Can someone give me a nudge in the right direction? I can't even wrap my head around this.
Also, how can I make this text actually look like an equation like I've seen in other posts? I'll edit it if someone can tell me how to change it, and I'll add the complicated mess I end up with in the end.
Well, you want to solve the last equation for t/r so see if you can get close to having no t's and r's on the other side and then look for some obvious substitutions to get rid of the t's and r's that are left. I don't know if that helps or not
As for putting equations in your posts, use Latex ([noparse][/noparse] tags--look at the sigma button that says "Show/Hide Latex Reference")
Thanks for your help. Can someone verify that this looks alright so far? :smile: Thanks lots.
\frac{1}{2}pr2+\frac{1}{2}qs2=\frac{1}{2}qt2
\frac{1}{2}pr2=\frac{1}{2}qt2-\frac{1}{2}qs2
\frac{(pr ^2)}{2}= \frac{(qt ^2 -qs ^2 )}{2}
2(pr2) = 2(qt2-qs2)
pr2 = qt2-qs2
p = \frac{qt ^2-qs^2}{r^2}
p+qs2 = \frac{qt ^2}{r^2}
\frac{p+qs^2}{q} = \frac{t^2}{r^2}
bluepillow, welcome to PF :smile:
It might be easier to define t/r be another variable, say "a":
a = t/r
then you can sub t = a*r in your last equation (EDIT: I mean the last equation in post #1). Work on eliminating everything till you're just left with one equation for "a".
For simple equations, you can copy-and-paste the symbols from here:
https://www.physicsforums.com/blog.php?b=347
For the LaTex stuff, the ∑ button shows up in "Advanced" edit mode. There's also info here:
https://www.physicsforums.com/misc/howtolatex.pdf
Be ready for some weird stuff to happen occasionally with LaTex. Sometimes, your edits will not show up right away, and you'll have to refresh the browser window to see them. And if you have a lot of LaTex equations in a single post, it can take awhile to load because an image file must be generated for each LaTex equation.
If you do a forum-wide search on LaTex or Tex, you'll find more info.
Great! Thank you, I'll try and work on this in the morning.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
