- #36
Eelco
- 52
Finbar said:Ok so as i see it the facts are that you can use QFT as an effective field and recover classical GR. This means you can use QFT to account for the bending of light. Here i refer to the papers of Donoghue et al already cited by humanino.
The question then remains. Can we interpret these results as graviton exchange? I think yes we can but we probably have to widen our ideas about what a "particle" really is. In particular we can't really stick with the idea that a graviton is a particle that "moves in space" because space and time are only defined in relation to the graviton. On the other hand its clear that the gravitational field once quantized can a)only transfer momentum in discrete packets and b) that information cannot travel faster than light. This must be true if you combine GR with QM. Given a) and b) its natural to want to interpret any given theory of QG based just on the principles of GR and QM as a "particle theory". But because of the nature of gravity the particle interpretation breaks down in the case of QG.
I think though that if we accept that quanta of the gravitational field are probably a reality but that these do not conform to our normal QM idea of a particle then it would perhaps be better to say that a graviton is a "quanta of the gravitational field" rather than a "particle".
Further more i would like to add that gauge fields e.g. photons also have geometrical interpretation. When we quantize them the geometrical interpretation doesn't go away but the interpretation of particles is then valid
Thank you, this seems like an honest and informed attempt at an answer to my question.
I know other fields also have a geometrical interpretation, but gravity is the only force which has an interpretation in terms of an evolution of metric, right?
A deformation of metric leads to gravity effects. Forces can similarly be transferred by particles. They may be but different interpretations of the same thing: I am cool with that, but one of these interpretations directly explains the appearent interaction with other force carriers (ie, light), whereas i completely miss the analogy of this effect in the other interpretation. Can i draw a feynman diagram where a photon absorbs a graviton, and thus alters its momentum/direction?
But essentially you are saying: a normal wave-particle interpretation is not applicable to gravitons. That would be a disappointment. How is that to be justified from a unification perspective? Has anyone ever simulated anything using gravitons, the way we have with photons or regge calculus? Do gravitons pass this basic sanity test?
