What is the Refractive Index for Total Internal Reflection in a 45-45-90 Prism?
The discussion centers on determining the minimum refractive index for a 45-45-90 prism immersed in water to achieve total internal reflection. Participants clarify that light entering the prism normally will hit the opposite face at a 45-degree angle, necessitating the use of Snell's law to find the refractive index. The correct application of Snell's law leads to the conclusion that the refractive index of the prism must be approximately 1.88. There is confusion regarding the medium, as one participant mistakenly referenced air instead of water, but this was later corrected. Ultimately, the consensus confirms that 1.88 is indeed the minimum refractive index required for total internal reflection in this scenario.
Cummings
The Question:
A 45-45-90 prism is immersed in water. What is the minimum index or fefraction the prism must have if it is to reflect totaly a ray incident normally on one of its faces.
Now, we have found this question a bit hard to understand.
We assume that light is hitting one of the sides at 90 degrees (normally) and so will pass into the prism without refraction. Thus, it hits the other side of the prism at an angle of incidence of 45 degrees.
This is where we get stuck, we are assuming that it is totaly internaly reflecting and by using snells law nSin(45) = Sin(90) we find that n, the refractive index of the prism is 1.88
This complies with
the fact that to be totaly internaly reflected the light must travel from a high refractive index (1.88) to a low refractive index (1 for air)
If we are on the right track, please let us know!
You didn't get n=1.88 using that equation. I assume you meant to write Snell's law as: n_1 sin\theta_1 = n_2 sin\theta_2. And, yes, the critical angle is found by setting \theta_2 = 90.
This complies with
If you assumed going from n=1.88 to air (n=1) I am very curious how you got your answer. (The prism is immersed in water, not air.)
I think it should be n1*Sin(45) = n2*sin(90), not nSin(45) = Sin(90)
which is
n1*sin(45) = 1.333
n1 = 1.333/sin 45
n1 is approx 1.88
Yes, i made a few erros in that post. Had to make it to the next class of uni.
Yes, the prism is in water. relinquished managed to type in what i failed to. He got the same answer to.
I just for some reason replaced water with air when i typed this up.
So, would 1.88 be the minumum index of refraction?
I knew you must have, since your answer was correct.
Yep.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
