What is the relation between Bernoulli's principle & Pascal?
In summary, Bernoulli's principle explains that in a fluid container, total energy remains constant under dynamic conditions and when the area decreases, the pressure decreases. Pascal's law states that a change in pressure in a fluid is transmitted equally throughout the fluid and Bernoulli's equation relates pressure, velocity, and height, but not area. Conservation of mass must also be considered when discussing the effects of area on pressure in a flowing fluid.
Swapnil Daji PAtil
Bernoulli's principle states that under dynamic conditions total energy inside the fluid container remains constant. and if area is decreases then pressure decrease . and
Pascal states that pressure = force/area . here if area decreases then pressure increase .
I'm getting confusing understanding how it is so?
please clear my problem ...
But that is for a stationary case - pressure from the heel or sole of a high heeled shoe, for instance.
Bernouilli is different. When a fluid is flowing into a narrow pipe section, the velocity has to increase, in order to get the same mass flow rate. That means there must be greater pressure before the constriction to accelerate the fluid.
If you are having trouble with this, then you have to realize that we are dealing with a steady state situation where the flows and pressures have settled down. Bernoilli doesn't say that suddenly inserting a narrow section will cause the pressure inside it to be lower; it says that everything will change. The pressure will end up lower than the pressure upstream. Also, when the constriction opens out to a wide section, the fluid will slow down and that involves a net back pressure, giving a higher pressure downstream than in the narrow section.
Likes Delta2 and vanhees71
does the pressure exerted by the fluid on the pipe decreases or is their any other logic behind it?
“Logic?”
The upstream pressure is higher than in the narrow section. Is that surprising? After all, you are ‘squeezing’ more water into less space.
Remember, the ‘drop’ in pressure is not ‘sucking’ fluid into the narrow part. We are describing the situation as it is after things have settled down.
If you are finding it non-intuitive then apply my argument and be prepared to go against intuition.
Intuition can be horribly wrong sometimes. ;-)
how p=f/a works here( in narrow section ) ?
That formula is a correct definition of pressure but you have to apply it correctly. With a solid object, the force is set (by the weight of the person, perhaps) and the area is set by the size of the shoe. You can alter the pressure by altering the size of the shoe. (p=F/a)
With a fluid, the static pressure is the same all over and two pistons of different areas, connected to the same fluid container will have the same pressure but different Forces. (F = Pa).
If you block the output of your pipes in the OP, the pressures will have the same values. Only when you start to allow fluid flow will Bernoulli come into play - for the reasons I gave (i.e. you need to accelerate the fluid into the narrow section etc. etc.)
okay now I got this . thank you very much
Also, please note that Pascal's law does not say ##p=FA##, and Bernoulli's equation says nothing about areas.
Pascal's law states that a change in pressure in a fluid is transmitted equally to all other parts of the fluid and leads to the development of hydrostatic pressure.
Bernoulli's equation relates pressure, velocity, and height but says nothing about area.
If you want to include area, you have to use the concept of conservation of mass in a flowing fluid.
Related to What is the relation between Bernoulli's principle & Pascal?
1. What is Bernoulli's principle?
Bernoulli's principle states that as the speed of a fluid (such as air or water) increases, its pressure decreases. This means that when a fluid is flowing faster, it exerts less pressure on its surroundings. This principle is often used to explain the lift of an airplane wing or the curve of a baseball.
2. What is Pascal's principle?
Pascal's principle states that a change in pressure applied to an enclosed fluid will be transmitted equally to all parts of the fluid. This means that if you push down on one part of a fluid, the pressure will increase throughout the entire fluid. This principle is the basis for hydraulic systems.
3. How are Bernoulli's principle and Pascal's principle related?
Both Bernoulli's principle and Pascal's principle are based on the properties of fluids. While Bernoulli's principle focuses on the relationship between fluid speed and pressure, Pascal's principle focuses on the transmission of pressure throughout a fluid. Together, these principles help us understand how fluids behave in different situations.
4. Can Bernoulli's principle and Pascal's principle be applied to the same system?
Yes, Bernoulli's principle and Pascal's principle can both be applied to the same system. For example, in a hydraulic lift, Pascal's principle is used to transmit the pressure applied to the smaller piston to the larger piston, while Bernoulli's principle can be used to explain how the speed of the fluid changes as it flows through the lift.
5. What are some real-life applications of Bernoulli's principle and Pascal's principle?
Bernoulli's principle and Pascal's principle have many real-life applications. Bernoulli's principle is used to explain the lift of airplane wings, the curve of a baseball, and the generation of sound by wind instruments. Pascal's principle is used in hydraulic systems, such as car brakes and construction machinery, to amplify force and make it easier to lift heavy objects. It is also used in medical devices, such as syringes and blood pressure cuffs.
  • Mechanics
  • Mechanics
  • Classical Physics
