What is the relationship between mass and weight?
In summary, the relationship between mass and weight is constant and proportional because weight is a force that is dependent on the mass and the acceleration due to gravity, which is typically taken to be constant near Earth's surface. This is also related to the units used to measure mass and weight, which can sometimes be used interchangeably but are technically different concepts.
harry_thawne
What does it mean that the relationship between mass and weight is constant and proportional?
I think I don't get it yet. The weight depends of mass, but at the same time depends of gravity, so if mass increase, the weight so does. But if we're on Earth we know that"g" has a value, therefore that "g" could be the constant in this equation that represents the relation: w=m⋅g, Is that the reason why the relationship between this two magnitudes is constant and proportional?
I hope I have explained myself well.
harry_thawne said:
Summary:: What does it mean that the relationship between mass and weight is constant and proportional?
Yes, insofar as ##g## is constant.
There are other ways of using the term weight, but what you describe is the way it's used in science and technology.
Weight is the force of gravity on a mass (typically, a mass that is not in freefall with respect to the source of the gravity). Because most human-related measurements and discussions occur near Earth's surface, we can take the proportionality between mass and weight to be g. g is not truly constant, it changes with location and height, but it's useful enough to treat it as constant for most things. If you're launching a rocket into orbit, then you have to be more nuanced.
This is also related to the units we use to describe mass and weight. When we talk about a pound we could mean a pound of mass (454 grams) or a pound of force (~4.4 Newtons), but the distinction doesn't matter as long as we stay near Earth's surface.
Likes vanhees71, bhobba and sysprog
Just to try and give a short answer. Mass is an intrinsic property of an object as expressed in the definition of force F=ma. Gravity accelerates objects with a constant acceleration regardless of mass. Since F=ma that means it experiences a force from gravity - sometimes called weight. Since acceleration is constant the force and hence weight is proportional to mass. Because of that they are in some contexts used interchangeably, but really are two different things.
Thanks
Bill
Related to What is the relationship between mass and weight?
1. What is the difference between mass and weight?
Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity acting on that object. In other words, mass is a measure of an object's inertia, while weight is a measure of the force required to accelerate that object.
2. How are mass and weight related to each other?
Mass and weight are directly proportional to each other. This means that as an object's mass increases, its weight also increases. However, the relationship between mass and weight is dependent on the strength of the gravitational force acting on the object.
3. Is mass the same as weight on Earth?
No, mass and weight are not the same on Earth. This is because the strength of gravity on Earth is not constant everywhere. For example, an object will have a different weight on the surface of the Earth compared to the Moon, even though its mass remains the same.
4. How is mass measured?
Mass is typically measured using a balance or scale. The most common unit of mass is the kilogram (kg), which is defined as the mass of a specific platinum-iridium alloy kept at the International Bureau of Weights and Measures in France.
5. How is weight measured?
Weight is typically measured using a spring scale or a balance scale. The most common unit of weight is the Newton (N), which is defined as the force required to accelerate a mass of one kilogram at a rate of one meter per second squared.
  • Mechanics
  • Mechanics
9K
  • Mechanics
  • Mechanics
