A What Is the Scale Length in SPARC Data Analysis?
  • A
  • Thread starter Thread starter mike_brandt
    Cosmology
The discussion focuses on understanding key terms in the SPARC data analysis, particularly the concept of scale length in relation to stellar disks. The scale length (Rd) is defined as the radius where the brightness profile, modeled exponentially, decreases by a factor of e. The term H I refers to neutral hydrogen atoms, which are crucial for mapping the distribution of galactic gas and calculating mass. Additionally, L[3.6] is confirmed to represent solar luminosity, similar to how M[solar] denotes solar mass. Clarifying these terms is essential for interpreting the SPARC data effectively.
mike_brandt
im reading through the sparc data and the accompanying scientific paper
SPARC: MASS MODELS FOR 175 DISK GALAXIES WITH
SPITZER PHOTOMETRY AND ACCURATE ROTATION CURVES
right now defining terms is my biggest problem
the reading through i come across the scale length' references are pg page, c colum, l line
pg2 c2 l10
"Column (9) gives the scale length of the stellar disk (Rd)."
what is the scale length
pg2 c2 l13
"Column (11) gives the total H I mass (M H I )."
i take it that the mass in relation to hydrogen . what is the i referencing
pg2 c2 section2.1. line4
i take this to be solar luminosity as a unit
L[3.6]
Space news on Phys.org
Scale length refers to the brightness profile when it is modelled as an exponential function (like the paper does). It is defined as the radius at which the central brightness (or whatever else is under consideration) has fallen off by a factor of e.
H I (H-one, not H-i) is a naming convention in astronomy referring to neutral hydrogen atom. Compare II = singly ionised, and III = doubly ionised (edit: obviously not applicable to hydrogen). The 21 cm hydrogen line is produced by H I atoms, letting you map neutral hydrogen distribution and calculate the mass of the (non-ionised) galactic gas.
Wikipedia has an article on this under 'Hydrogen line'.
##L_\odot## is solar luminosity, yes. Same as ##M_\odot## is solar mass.
Likes ohwilleke and James William Hall
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
