What is the significance of a complex commutator?
The discussion revolves around the significance of the complex commutator in the context of operator exponentiation. Participants explore the relationship between operators A and B, defined by the commutation relation [A, B] = λ, and how this affects the expression exp[μ(A + B)]. There is debate on whether to use the Baker-Campbell-Hausdorff (BCH) formula for simplification, as it may provide a more straightforward solution than expanding the exponentials. The importance of the imaginary nature of the complex numbers λ and μ is also questioned, particularly in relation to the uncertainty principle. Ultimately, the conversation emphasizes the complexities of operator algebra and the utility of the BCH formula in handling non-commuting operators.
Darkmisc
If A and B are two operators such that
[A,B] = λ , where l is a complex number, and
if μis a second complex number, show that:
exp[μ(A + B)] = exp(μA)exp(μB)exp(- λμ^2/ 2).
I'm stuck on where to begin. I know that the result [x, p_x] = ih_bar indicates that x and p_x relate by the uncertainty principle. I'm not sure if this conclusion applies to complex commutators in general.
Also, I don't understand the significance of the exponential function. Do I lose anything by expressing that information as
μ(A+B)=(-λμ^2)/2 ?
Any ideas?
Thanks
I can't figure out why the imaginaryness of λ and μ is important (at least formally). Exponentiating an operator means nothing more than the infinite power series of the exponent (Taylor series). I think that it's actually technically defined this way. So, for example:
exp(μA) = 1 + μA + (1/2)μ2A2 + (1/6)μ3A3 ...
So, just expand each exponential, multiply the r.h.s. out, and then collect terms of the same order in μ. If you can stand it, you might work all the way up to order μ4, but you will begin to see the point even at order μ2.
CAUTION: WHEN YOU EXPAND OPERATOR EXPRESSIONS, THE COMMUTATIVE LAW FOR MULTIPLICATION MAY NOT APPLY ...
μ(A+B)=(-λμ^2)/2 ?
Where did you get that?
oops, I messed up that expression. I meant to equate the indices.
There are operators A and B, and then there are parameters λ and μ; what indices?
Could this be done easier using BCH formula due to non-commuting? Expansion doesn't seem to get anywhere.
edit: I guess I don't mean putting it through the entire thing, just the result for exp(A +B) = exp(A)exp(B)exp([A,B]/2), but then again I'm also clueless.
sgnl03 said:
Could this be done easier using BCH formula ...
Sure, it would be MUCH easier using the BCH formula (almost trivial). I was assuming that the problem is an excercise to demonstrate a nontrivial exponentiation of operators, and if the point was to use the BCH formula, then they would have at least made the commutator more complicated (like proportional to A or B). Of course, this is just an assumption, and since the problem statement doesn't disallow it, BCH formula is probably the way to show something like this in practice.
I don't know what you mean. Expansion must get somewhere, and it is a good excercise to formally match terms according to an order parameter (μ in this case.) Of course, then you must also make use of
BA = AB - [A,B]
etc.
This is correct. You know that you can stop there because the commutator is a scalar. In effect, that IS "the entire thing", and anyway "the entire thing" apparently doesn't have (what a would call) a closed form (at least it doesn't look very elegant in general).
Cheers, Thanks.
