What is the significance of gravitational units in understanding momentum?
Gravitational units refer to a measurement system that expresses force relative to the acceleration due to gravity, typically at sea level (9.8 m/s²). This concept is often represented in terms of "G's," where one G corresponds to the force experienced under Earth's gravity. When discussing momentum in gravitational units, it involves calculating force as F=m(#G's)g, where #G's indicates the multiple of gravitational force experienced. The conversation also highlights confusion regarding the term "gravitational unit of momentum," suggesting a lack of clarity in educational resources. Understanding gravitational units is essential for grasping how forces and momentum are experienced in different gravitational fields.
Rakinniya
What are gravitational units??
My teacher recently taught us about gravitational units... she said that its the absolute unit multiplied by acceleration due to gravity... I did not understand the significance of this...Please help me
I have never heard of "gravitational units", but based on your second phrase, "… she said that its the absolute unit multiplied by acceleration due to gravity…", I would guess that she is referring to what is commonly called "G's"; as in , " The astronauts experienced 4 G's during their blastoff."
Assuming this is what she meant, then this is an expression of force in terms of the force due to gravity at sea level on earth.
If you stand on Earth at sea level, the force on you is F=mg where g is the acceleration due to gravity at sea level on earth(i.e. 9.8 m/s^2).
If you next were to stand on another planets surface where you felt two times the force of gravity you felt on Earth then the equation could look like
F=2mg=m2g
so that you weigh twice what you did on earth, hence you feel 2"G's".
So the general rule is when you are given the number of "G's" you multiply that times the acceleration g(9.8m/s^2) to find the force.
F=m(#G's)g.
Hope this helps.
(note:The G used here is NOT the gravitational constant)
tnx that was quite helpful... but em not sure if she meant the same thing... ..I can't find nything in my textbook .today...she asked us. "what is the gravitational unit of momentum?"...Theres an article on ...Gravitational metric system in wikipedia... Looks like its an outdated one...anyway thanks!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
