What is the size and shape of single optical photon?
In summary, the shape and size of a single optical photon has been a topic of discussion and research. One article by Geoffrey Hunter suggests that it has a shape similar to an elongated ellipsoid with a length of the wavelength and a diameter of λ/π. Other articles have also proposed different dimensions for a photon, such as a thickness of 1 Planck Length and a length of half the wavelength. However, the concept of particles as point objects is outdated and now everything is seen as a wave, with the wave motion occurring in dimensions perpendicular to the direction of travel. This has implications for understanding atomic processes and phenomena such as the observed delay in photoemission.
Jarek 31
158
31
TL;DR Summary
What is the shape and size of energy distribution of optical photon?
Optical photon is produced e.g. during deexcitation of atom, carrying energy, momentum and angular momentum difference.
So how is this energy distributed in space - what is the shape and size of single photon?
Looking for literature, I have found started by Geoffrey Hunter, here is one of articles: "Einstein’s Photon Concept Quantified by the Bohr Model of the Photon" https://arxiv.org/pdf/quant-ph/0506231.pdf
Most importantly, he claims that such single optical photon has shape similar to elongated ellipsoid of length being wavelength λ, and diameter λ/π (?), providing reasonably looking arguments:
1) Its length of λ is confirmed by:
– the generation of laser pulses that are just a few periods long;
– for the radiation from an atom to be monochromatic (as observed), the emission must take place within one period [10];
– the sub-picosecond response time of the photoelectric effect [11];
2) The diameter of λ/π is confirmed by:
– he attenuation of direct (undiffracted) transmission of circularly polarized light through slits narrower than λ/π: our own measurements of the effective diameter of microwaves [8,p.166] confirmed this within the experimental error of 0.5%;
– the resolving power of a microscope (with monochromatic light) being “a little less than a third of the wavelength”; λ/π is 5% less than λ/3, [12];
Is it the proper answer?
Are there other reasonable answers, experimental arguments?
A classic photon particle by definition will always be just a zero-dimensional point particle, meaning it has no length, width, or height. But looking at it in the QFT viewpoint, it's a disturbance in the photon field, then a photon will be a vibration along the width and height dimensions, but no vibrations along the length dimension. Basically just a flat pancake-like object with the vibrational flatness perpendicular to its direction of travel. The thickness of its vibrational edge might have maximum thickness of 1 Planck Length, if it isn't a perfectly zero length thickness.
I believe you are referring to Feynman diagrams: perturbative series approximation of QFT in momentum space - shouldn't we use nonperturbative in position space to get size of particles?
Perfect point particle would have infinite energy density - e.g. forming a black hole.
Photon is EM wave configuration, its hv energy is somehow distributed rho~|E|^2+|B|^2 over some volume - we should be able to describe at least its dimensions, e.g. averaged over quantum ensemble.
I have also found two more papers: https://arxiv.org/pdf/1604.03869
the length of a photon is half of the wave length, and the radius is proportional to square root of the wavelength
2021 "The size and shape of single photon" http://dx.doi.org/10.4236/oalib.1107179
A point particle isn't necessarily a black hole, it's just the average center of a packet of energy that we call a particle. Pack enough energy and mass into that point, then yes it becomes a black hole, but that energy level is the Planck Energy and the Planck Mass. Anyways, the whole concept of particles is now outdated, everything is now just a wave, and the point is just a mathematical abstraction useful for mapping the average locations of these "particles".
Particles moving at the speed of light will not have any wave motion in the direction of travel, all of the wave motion will occur in dimensions perpendicular to the direction of motion. Thus the wave motion will look like a pancake or a disk, very thin in the direction of travel, spread out in the perpendicular directions.
  • Skeptical
Likes weirdoguy
The question of size of single photon seems similar as of the size of this packet of energy - distortion of rho~|E|^2+|B|^2 from center in position space (in momentum space we would ask for monochromaticity).
If this size as position distortion would be zero, then density would be infinite - forming black hole, but this boundary is really tiny like ~10^-57m for electron ( https://en.wikipedia.org/wiki/Black_hole_electron ).
Indeed everything is just a wave - of EM field in case of photon, its interference e.g. leads to reflection from mirror as explained in Feynman lectures.
The big question is understanding atomic processes from such EM wave perspective - e.g. there was observed ~22as delay in photoemission ( https://science.sciencemag.org/content/328/5986/1658 ) - what exactly happens during this time of e.g. photon creation?
  • Skeptical
Likes weirdoguy
Any source for that? I've read quantum mechanics and QFT textbooks and no one said such things. Of course defining particles in quantum context is a little bit tricky and not always possible, and we use a lot of wave-like equations, but that's far from "everything is a wave". That's good for pop-science talks, a poor ones if you ask me.
Any source for that? What is a "vibrational edge"?
No, it's not. It's one-particle Fock state, EM waves are something different.
Yeah, textbooks are not really the greatest sources of understanding and interpretting, more just about "shut up and calculate". QFT pretty much gives up on the idea of particles. Particles are just more and more constricted waves on a field now.
  • Skeptical
Likes Motore and weirdoguy
To the contrary, textbooks (or lectures) are the best (if not the only) sources you can get any understanding of QFT from.
Most certainly it does not, as most of the textbooks show.
So, what are the sources for your claims?
First of all, QFT is usually used through Feynman diagrams - approximation with perturbative series in momentum space.
We can ask about monochromacity there, but this is still an approximation - to really understand shapes of particles with QFT, you would need to use nonperturbative in position space.
You can do your calculations in position space, it's just more convenient to that in momentum space.
Jarek 31 said:
Like the claims of electron being a perfect point, which make no sense from so many reasons
Well, it makes sense to particle physicists and others involved. At least in some contexts.
Jarek 31 said:
and experimental evidence don't confirm it:
Experimental evidence is in agreement with it.
Thread closed temporarily for Moderation...
There isn't any. A photon is not a classical object; it doesn't have a "distribution in space". It doesn't even have a well-defined spatial wave function, which is the closest thing a quantum particle with nonzero rest mass, like an electron, has to a "distribution in space".
Not really. The model being used in the paper you reference is classical, not quantum. The paper claims to be able to account for one particular phenomenon--interference in the double slit experiment when done with light--using its model. This is hardly a breakthrough, since the fact that classical Maxwell electrodynamics predicts interference in this experiment has been known since the 19th century. However, there are still many, many experimental results involving photons that classical Maxwell electrodynamics cannot account for; one key phenomenon is the very fact that we can build "photon detectors" that emit single clicks (or show single flashes of light) when single photons hit them--such detectors are of course common in quantum optics experiments.
This means that the classical Maxwell model of light is only an approximation, valid in certain cases, but not a valid general theory of all phenomena involving photons. (Even the concept of "photon" used in the paper, i.e., a classical "wave packet", is not the same as the quantum concept of a photon.)
The "reasonable answer" is the one I gave at the start of this post. (The more technical version of that answer is that Newton-Wigner localization fails for photons, but discussing that would take this thread into "A" level territory.)
They both have the same problem as the other paper, which I explained above. Basically, none of the papers you are reading are talking about photons at all. They are talking about the classical model of light, and they are concentrating on experiments where that model makes reasonably accurate predictions. The reason that is the case is that those experiments don't even involve "photons" at all--the light sources being used are nothing at all like the "single photon" sources that quantum physicists use. They are just ordinary classical light sources that are useless for exploring any of the quantum properties of light.
Likes phyzguy
There is no such thing.
This is nonsense. I don't know where you are getting your "QFT viewpoint" from, but wherever it is, it does not appear to be a reliable source.
This is all just speculation. Plausible-sounding speculation that a number of physicists have made, but still speculation.
Again, I don't know where you are getting your information from, but it does not appear to be a reliable source.
This will come as a great surprise to all of the people who call themselves "particle physicists".
The concept of "particle" in QFT is certainly more complicated than just "little billiard ball" or "point particle". But that doesn't mean the concept has been "given up on".
The QFT concept of "field" is, if anything, less like its classical counterpart than the QFT concept of "particle". I think you need to check your understanding.
Likes weirdoguy
I am reopening the thread in case any members have useful references on quantum optics, which should be much better sources for the OP to learn from than the papers so far linked to in this thread.
Everyone, please bear in mind the PF rules on personal theories and personal speculations.
Likes weirdoguy
Saying that particles are perfect points in Feynman diagrams: Dirac deltas in perturbative QFT in momentum space ... wouldn't it mean that they are plane waves in position space?
Plane waves cover entire universe - should we imagine that e.g. photons now going from screen to our eyes are plane waves of infinite size?
If not, please provide better arguments, preferably based on experiments which are the best arguments - like lower bound for duration of ultrashort laser pulse, or weakening transmission through hole in wavelength scale?
Delta functions in perturbative QFT in momentum space do not "say that particles are perfect points". They are there for momentum conservation, not to model point particles.
Unfortunately, your whole approach to this question is flawed, and given your responses so far to having that pointed out, you are unable to recognize "better arguments" when they are presented to you. Given that, I am closing this thread again, this time permanently.
FAQ: What is the size and shape of single optical photon?
What is the size of a single optical photon?
The size of a single optical photon is incredibly small, with a wavelength ranging from 400 to 700 nanometers. This is approximately 1000 times smaller than the width of a human hair.
Does the size of a single optical photon vary?
Yes, the size of a single optical photon can vary depending on its wavelength. Photons with shorter wavelengths have smaller sizes, while those with longer wavelengths have larger sizes.
What is the shape of a single optical photon?
A single optical photon does not have a defined shape as it is a particle of light. It is often described as a wave-particle duality, meaning it can exhibit both wave-like and particle-like behaviors.
How is the size and shape of a single optical photon measured?
The size and shape of a single optical photon can be measured using various techniques such as diffraction, interference, and scattering experiments. These methods involve interacting the photon with other particles or surfaces and observing the resulting patterns.
Can the size and shape of a single optical photon be manipulated?
Yes, the size and shape of a single optical photon can be manipulated using various techniques such as focusing, polarizing, and filtering. These methods can alter the direction, intensity, and polarization of the photon, effectively changing its size and shape.
