What Is the Smallest Spot Diameter the Human Eye Can Detect?
The smallest spot diameter the human eye can detect is influenced by the pupil diameter and the wavelength of light. With a pupil diameter of 2.59 mm and a wavelength of 550 nm, the resolving angle was calculated to be approximately 1.98E-4 radians. The distance to the first minima was found to be 5.03 μm, leading to a calculated spot size of 10.06 μm, although the correct answer is 9.85 μm. The index of refraction of the vitreous humor alters the wavelength of light, which affects the calculations. Using the correct wavelength of 0.412 μm instead of 0.42 μm was crucial for accurate results.
aDabOfRanch
The resolution of the eye is ultimately limited by the pupil diameter. What is the smallest diameter spot the eye can produce on the retina if the pupil diameter is 2.59 mm? Assume light with a wavelength of λ = 550 nm. (Note: The distance from the pupil to the retina is 25.4 mm. In addition, the space between the pupil and the retina is filled with a fluid whose index of refraction is n = 1.336.)
Hint: The size of the spot is twice the distance from the main axis to the first minimum.
θrad=1.22λ/D
tanθ=Ym/L
Found the resolving angle using θrad=1.22λ/D where D is the diameter of the pupil, and the angle turned out to be 1.98E-4 radians. Then I used the angle to find the distance from the main axis to the first minima by plugging in θ into tanθ=Ym/L solving for Y1 I got 5.03
Using the hint provided I doubled 5.03 to get 10.06μm however the answer is 9.85μm
Hi aDabOfRanch,
Welcome to Physics Forums!
What do you think might be the effect of the index of refraction of the vitreous humor (fluid filling the eye)?
gneill said:
Hi aDabOfRanch,
It causes the light to bend in the eye. I forgot to mention that in my post, sorry! λfilmvac/n which turns out to be 412nm or 0.412μm
So it alters the wavelength. What value of wavelength did you use when you calculated the value for θrad?
I used λfilm but I wrote 0.42μm instead of 0.412μm which was messing up the calculations.Thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
