What is the Speed of a Block After Traveling 0.9 m Up an Inclined Plane?
A block of mass 1 kg is placed on a spring with a constant of 500 N/m at the bottom of a frictionless inclined plane angled at 30°. When released, the block travels 1.5 m up the plane, and the problem asks for its speed after traveling 0.9 m. The user attempted to apply the work-energy principle but encountered issues with obtaining results that fit the multiple-choice options. There is confusion regarding the use of the angle in calculations and how to properly format equations in the forum. Proper formatting can be achieved using the site's editing tools or LaTeX syntax for clarity in posts.
Quantum Singularity
I have run across another problem while reviewing for finals that I am not able to really understand, and this one I have no clue how to approach. I am given that a block is of mass 1 kg, it is placed on a spring of constant 500 N/m at the bottom of a frictionless plane inclined at 30°. When the spring is released the block travels 1.5 m up the plane, losing contact with the spring. What is the speed of the block when it has traveled 0.9 m up the plane?
Not really sure, I tried using:
W=(1/2)kx2
and:
K=(1/2)mv2
So, I tried finding the work, and then using the work in place of K to find the velocity. This returned double digit numbers, which due to the question being multi-choiced with only single digit numbers, are obviously wrong. Also, where am I supposed to use the supplied angle?
On a side note, how do you format your posts so the equations look nice as you see in a lot of other posts on these boards?
You'll have to show your attempt in detail so that we can see what you did right and where you went wrong.
As for equation formatting, you can use the icons and menus available in the edit panel header bar for things like subscripts and superscripts and special characters (such as Greek letters) if you use plain text equations, or you can use the built-in LaTeX syntax interpretation that the website implements. This requires learning some LaTeX syntax. For more information check out the LaTeX Primer.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
