What is the stress of the rotated axis
In summary, the conversation discusses the components of stresses in rotated axis, given only the triaxial stresses of ax = 10 MPa (along [100]), ay = 10 MPa (along [010]), and ax = -30 MPa (along [001]). The equation aT = [L][a][LT] is used to determine the components of stress in rotated axis, where aT is the components of stress of rotated axis, L is the direction cosine, LT is the inverses of direction cosine, and a is the component of stresses in unrotated axis. However, without an angle of rotation or shear stress given, L and LT cannot be determined. The component of L along x and x', L
ralden
85
Given only the triaxial stresses: ax = 10 MPa (along [100]), ay = 10 MPa (along [010]), and ax = -30 MPa (along [001]), what is now the components of stresses in rotated axis?
so based on the equation
aT = [L][a][LT]
let aT the components of stress of rotated axis, L the direction cosine, LT the inverses of direction cosine and a is the component of stresses in unrotated axis.
we can determine a, but we can't determine L or LT because there's no angle of rotation given or shear stress given. since L is equal to
Lxx = (e'x)*(ex)*(cos(theta))
Lxx is the component of L along x and x', and theta is the angle between the rotated axis and unrotated axis
so now, how can i determine the stress in rotated axis?
Is this a homework problem? If so, please state the problem exactly.
Related to What is the stress of the rotated axis
What is the stress of the rotated axis?
The stress of the rotated axis refers to the amount of force or pressure that is applied to an object due to its rotation around an axis. This stress can cause deformation or strain in the object and can impact its structural integrity.
How is the stress of the rotated axis calculated?
The stress of the rotated axis is calculated using the formula τ = Fr/I, where τ is the stress, F is the applied force, r is the distance from the axis to the point of application of the force, and I is the moment of inertia.
What are the factors that affect the stress of the rotated axis?
The stress of the rotated axis is affected by several factors, including the magnitude and direction of the applied force, the distance from the axis to the point of application of the force, and the shape and material properties of the object.
How does the stress of the rotated axis impact an object?
The stress of the rotated axis can cause an object to undergo deformation, which can lead to changes in its shape, size, and structural integrity. If the stress exceeds the object's strength, it can result in failure or breakage.
How can the stress of the rotated axis be reduced?
The stress of the rotated axis can be reduced by distributing the force over a larger area, increasing the distance from the axis to the point of application of the force, and selecting materials with higher strength and stiffness. Proper design and engineering techniques can also help in reducing the stress on an object.
  • Mechanical Engineering
  • Other Physics Topics
  • Materials and Chemical Engineering
