What Is the Sum of the Digits of 3n Given These Conditions?
  • MHB
  • Thread starter anemone
In summary, The purpose of "Find the Sum of Digits of 3n" is to find the sum of the digits of a number that is three times another given number. This can help in solving mathematical problems and understanding patterns in numbers. To find the sum of digits of 3n, you first multiply the given number by 3. Then, you add up all the individual digits in the resulting number. This sum is the sum of digits of 3n. Finding the sum of digits of 3n can help in understanding the properties of numbers and identifying patterns. It can also be used in various mathematical calculations and problem-solving strategies. Some tips for solving problems involving finding the sum of digits of 3n include breaking down
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
A number $n$ has sum of digits 100, while $44n$ has sum of digits 800. Find the sum of the digits of $3n$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulatons to kaliprasad for his correct solution!(Cool)
Here is a suggested solution by other:
Suppose $n$ has digits $a_1a_2\cdots a_k$ and digit sum $s=\sum a_i$. If we temporarily allow digits larger than 9, then $4n=(4a_1)(4a_2)\cdots(4a_k)$. Each carry of one reduces the digit sum by 9, so after making all necessary carries, the digit sum for $4n$ is at most $4s$. It can only be $4s$ iff there are no carries. Similarly, $11n$ has digit sum at most $2s$, with equality iff there are no carries.
Since $44n$ has digit sum $8s$, there cannot be any carries. In particular, there are no carriers in forming $4n$, so each digit of $n$ is at most 2. Hence, there are no carries in forming $3n$ and the digit sum of $3n$ is 300.
FAQ: What Is the Sum of the Digits of 3n Given These Conditions?
What is the purpose of finding the sum of digits of 3n?
The purpose of finding the sum of digits of 3n is to determine the digital root of a number. This can be helpful in various mathematical calculations, such as determining divisibility and finding patterns in numbers.
How do you find the sum of digits of 3n?
To find the sum of digits of 3n, you first need to multiply the number by 3. Then, you add up all the digits of the resulting number. This sum is the sum of digits of 3n.
What is the significance of 3n in this problem?
The number 3n is used in this problem because it allows us to easily determine the digital root of a number. Multiplying a number by 3 is equivalent to adding up all its digits, and this makes it easier to find the sum of digits of 3n.
Can you provide an example of finding the sum of digits of 3n?
Sure, let's say we have the number 123. Multiplying it by 3 gives us 369. Then, we add up all the digits of 369, which gives us 3+6+9=18. Therefore, the sum of digits of 3n for the number 123 is 18.
How is finding the sum of digits of 3n useful in real life?
Finding the sum of digits of 3n can be useful in various real-life situations. For example, it can help in determining the check digit of a credit card number, or in solving certain coding and programming problems. It can also be used in number theory and cryptography.
