What is the tension in a charged ring?
In summary, the conversation discusses an attempt to find the electric field and tension on a piece of a ring with a homogenous linear charge. However, this scenario may not be valid as the charge density may diverge at the point charges and be zero elsewhere, making the electric field undefined. Additionally, calculating tension on a perfect circle may also be problematic as the electric field is not radial and may not have a nice mathematical form. The suggestion is made to consider a finite set of charges and try to calculate the tension on a small element of the ring to potentially get a useful expression.
  • #36
Vanadium 50 said:
Draw the field lines (which will be radial) outside the ring. Make the ring smaller. Do I have any more field lines? If so, where did they come from? Do I have less? If so, where did they go? Continue until the ring is a point.
It works for a 3D sphere, yes, but not for a 2D ring. There is not the necessary symmetry of field lines, we cannot yet tell whether the field strength is uniform in all directions.
For a 3D sphere, spherical symmetry implies uniform density of field lines emanating from the sphere. Theorem of Gauss tells me that, with a suitable spherical domain of integration $$\int_S \vec{E} \cdot d\vec{A} = 4\pi r^2 E= \frac{Q}{\epsilon_0}$$ and hence ##E = \frac{Q}{4\pi \epsilon_0 r^2}##. But now let us consider a 2D ring. What surface are you integrating over? What symmetry do you invoke to ensure uniformity of field lines over this surface?
  • #37
DRAW THE FIELD LINES.
Don't just tell me it doesn't work so you don't have to draw them. I'm trying to teach you something here, but I can't if you don't do anything I suggest. But I give up. Do it whatever way you want.
  • #38
To the best of my knowledge, here is what I imagine the electric field to look like
black denotes the plane of the ring, red are a few extra outside of the plane of the ring. I missed out a few in the axial directions because I thought it would make the diagram unnecessarily hard to read. Now I construct an arbitrary control volume ##V## that encloses the ring. I can use the integral form of Gauss' law again, $$\int_S \vec{E} \cdot d\vec{A} = \frac{Q}{\epsilon_0}$$but I don't know how you can extract ##E## from that, because there is only a radial symmetry, and not a spherical symmetry like in the previous case.
I apologise if I upset you @Vanadium 50, but I can assure you I ask out of interest and not stubbornness :wink:. I appreciate your help. After all, you have the PhD and I do not 😁
  • #39
If the tension in the ring is finite, then the tension is equal to 1/2 of the force ##F## that one half of the ring exerts on the other half. For the case where the thickness of the wire (or thread) is zero, the tension will not be finite. But, I thought it would be interesting to put a couple of gaps in the ring as shown below and consider how the force ##F## varies with the size of the gap, ##S##. ##S## is the arc length of each missing piece of the ring.
The force ##F## can be found by integration and I got the following result. For convenience, let ##z## denote the size of the gap in relation to the circumference of the ring: ##z = \frac{S}{2 \pi R}##.
$$F = 2k\lambda^2 \left[ \cos(\pi z) \log \left[ \cot \left(\frac{\pi z}{2} \right) \right] + \sin (\pi z) - 1 \right ]$$
##k## is Coulomb's constant. I think this is valid for any nonzero gap size; that is, for any ##z## in the range ##0<z<\frac{1}{2}##. (As ##z## approaches ##\frac{1}{2}##, the gaps consume the whole ring.)
Here are some numbers for a ring of circumference 1 meter and ##k \lambda^2=1##N. (So, ##\lambda## is about 10 μC/m.) The gap is varied from 10 cm to 1 × 10-13 m, which is much smaller than the size of an atom!
The force increases surprisingly slowly as the gap size decreases. For ##z << 1##, the formula for ##F## can be approximated as $$F = 2 k \lambda^2 \left[ \log \left(\frac{2}{\pi z} \right) - 1 \right]$$
This shows how the force diverges logarithmically as the gaps shrink to zero.
  • Love
Likes Hamiltonian, Pi-is-3, Delta2 and 3 others
  • #40
TSny said:
The force increases surprisingly slowly as the gap size decreases. For ##z << 1##, the formula for ##F## can be approximated as $$F = 2 k \lambda^2 \left[ \log \left(\frac{2}{\pi z} \right) - 1 \right]$$This shows how the force diverges logarithmically as the gaps shrink to zero.
This is very cool, thanks a bunch for the analysis! It's quite fun to play around with the formulae you provided.
I think I am probably quite (very) out of my depth to replicate the result, but I will have a go :wink:.
Thanks!
  • #41
Vanadium 50 said:
If you don't want to follow the proof, here's the heuristic. In the plane of the ring, field lines are radial by symmetry. I can always replace the ring by one a factor of 2 (or 10, or a million) smaller without changing the field strength anywhere it wasn't zero. (Obviously points that were inside and are now outside see different fields). Do that as many times as you want and you get your ring arbitrarily close to a point.
That only says it is radial, so yes of course it is equivalent to some charge at the central point. I did not dispute that, and I would hope it was obvious to us all. The question is, what charge at the central point? Certainly not the total charge on the ring, as you seemed to imply by referring to the shell theorem without qualification.
Edit: indeed, looking back, I see you specifically stated as much:
Vanadium 50 said:
The total charge is 2πRλ, Because of the shell theorem, I can treat this as coming from a single point at the center of the loop.
In particular, is it even finite? Everyone else in the thread was coming to the view that it probably was not, and I see @TSny has now confirmed that.
So to get a useful answer to the original question, the ring must be modeled as a torus, at least locally to the "test charge" point.
Likes Adesh and etotheipi
  • #42
But it is only equivalent in the plane, right? As far as I can tell there's no telling whether the field above the ring is also like that from a point charge, but my spidey-senses tell me that it's probably not. And that is why we can't deduce even the electric field outside the ring in the plane of the ring by heuristic arguments alone, because the problem lacks spherical symmetry.
I haven't made much progress with the torus today, but I will try harder tomorrow :wink:
  • #43
Agreed. It will not even seem like a point source when sensed across some small region. What I mean by that is that since the equipotential surfaces are not spheres they will locally have two different radii.
There's an interesting question... at a point on the ring, what is the curvature of the equipotential in a plane normal to the ring and through its centre?
Likes etotheipi
  • #44
I downloaded this wolfram project and apparently this is what the electric field looks like around such a charged ring:
It looks like we can vaguely imagine various equipotential surfaces (easier on the left diagram) by tracing through perpendicular to the field lines, as a first "approximation" 😁.
Likes Delta2 and haruspex
  • #45
View attachment 265446View attachment 265447
Yes, it dawned on me that in the vicinity of the ring the equipotentials will be toroidal shells around the ring.
Likes etotheipi
  • #46
@etotheipi asked me to come back. Let me make a few comments:
People are, often implicitly, interpreting "negligible thickness" as "the ring is a torus, and we are taking the limit as the minor axis goes to zero." That reads more into the problem than is there. Further, they are discovering infinities when they do this. There are. The same infinities come up with any "line of charge" problem. Indeed, these infinities even come up when imagining a test charge as a tiny sphere of charge Q and letting the sphere radius go to zero. So to solve this, we take a "line of charge of charge density λ" at its word and...
It is a mistake to set up a problem so that the very elements of that problem are infinite.
So, I'm am taking the problem at its word - "negligible thickness" means treat this as a 2D problem, not as a 3D problem where I do not neglect the thickness. If you want to complain that this is not physically realizable, you can get in line with people complaining about frictionless surfaces, stretchless ropes, perfect spheres, etc.
Next, let's take a look at the picture in #38. The red lines are out of the plane and therefore irrelevant. I count six field lines in the plane. At 2R, 3R, 100R, I always have six lines. Everywhere outside the ring, the field configuration configuration looks like all of the charge is concentrated at a tiny point in the center of the ring.
Why take the outside field? Because it is finite, and presumably the author of the problem is looking for a finite answer.
OK, so what is the potential energy of this configuration? Let's look at a tiny slice of wire - say 1/1000th of it. It sees the field as if all the charge were at the center, and it's R units away. So it's [1/1000][1/4πε0][Q2/R]. There are 1000 such pieces, so the total is [1/4πε0][Q2/R]. A million pieces? Same answer. A trillion? Same answer.
So the energy change of moving the circle from R to R + ΔR is [1/4πε0][(2πλ)2ΔR/R2]
The energy it takes to stretch a spring from R to ΔR is 4π2kRΔR.
Equating,
[tex]4\pi^2kR\Delta R = \frac{1}{4\pi\epsilon_0}\frac{(2\pi R \lambda)^2}{R^2}\Delta R[/tex]
or
[tex]k = \frac{1}{4\pi\epsilon_0}\frac{\lambda^2}{R}[/tex]
and so (if I didn't make an algebra error)
[tex] T = 4\pi^2 k R = \frac{\pi}{\epsilon_0}\lambda^2 [/tex]
Likes Paul Colby, etotheipi and Delta2
  • #47
Please explain how you arrive at that. We all accept that by symmetry the net field is radial, but do not understand how you get that it is equivalent to the actual charge on the ring relocated to the centre (as it would be for a sphere).
In particular, you seem by this to magic away an infinity (or, equivalently, a critical dependence on the wire thickness) which provably exists.
Likes etotheipi, Adesh and Delta2
  • #48
First of all only the field at the plane of the ring looks like as all the charge was at the center of the ring, but then again this is not accurate because we know that the field at the infinitesimally thin ring becomes infinite, while if we take the charge to be concentrated at the center, then the field at the thin ring is not infinite but has a finite value, it is right at the center that the field becomes infinite. So at first glance you move the infinity from the place of the thin ring to the place of center of the ring, so the two configurations do not seem to be equivalent (as they are equivalent in the case of a charged sphere with surface charge density, because we have spherical symmetry there).
Likes etotheipi and Adesh
  • #49
Go back to counting field lines. If I have six at 10R and 2R, if I replace the ring with a smaller one - say R/4 - with the same change, I will still have six at 10R and 2R. And at R and R/2. Repeat as necessary.
There is no "center" to a ring of zero thickness (and/or height).
  • #50
Yup. And why am I doing this? Because the problem said to.
  • #51
Am I right in thinking you have interpreted this as a problem in a 2D universe, effectively turning the ring into an infinite cylinder?
Likes etotheipi
  • #52
This would be interesting. AFAIK there are no constraints that limit Gauss' law to a 3D universe, except the equation would be in a 2D universe,$$\oint \vec{E} \cdot \hat{n} dl = \frac{q}{\epsilon_0}$$where we are integrating around a closed curve, and ##\hat{n}## is orthogonal to the curve. This would mean that the field seen just outside the ring, in the 2D universe, would be (using the radial symmetry)$$E = \frac{q}{2\pi \epsilon_0 r}$$This is like the infinite cylinder in the 3D universe. It would appear to permit a logarithmic electric potential.
  • Skeptical
Likes Adesh
  • #53
etotheipi said:
This would be interesting. AFAIK there are no constraints that limit Gauss' law to 3D, except the equation would be in 2D,$$\oint \vec{E} \cdot \hat{n} dl = \frac{q}{\epsilon_0}$$where we are integrating around a closed curve, and ##\hat{n}## is orthogonal to the curve. This would mean that the field seen just outside the ring, in the 2D universe, would be (using the radial symmetry)$$E = \frac{q}{2\pi \epsilon_0 r}$$But that would seem to give a logarithmic electric potential.
Gauss' law is just an application of divergence theorem in the case of electromagnetism, that is
\int_V (\nabla \cdot \mathbf E) dV = \oint_S \mathbf E \cdot d\sigma
We have to have a surface.
  • #54
The divergence theorem holds in any number of dimensions. In 2D the closed curve becomes the surface.
  • #55
I would really like to know if there exists some references for that claim.
  • #56
From Wikipedia:
In physics and engineering, the divergence theorem is usually applied in three dimensions. However, it generalizes to any number of dimensions. In one dimension, it is equivalent to integration by parts. In two dimensions, it is equivalent to Green's theorem.
Also have a look here: https://arxiv.org/pdf/1809.07368.pdf. It is noted that in 2 dimensions the electric field of a point charge at ##\vec{r}'## goes as$$\vec{E} = \frac{q}{2\pi \epsilon_0|\vec{r}-\vec{r}'|^2} (\vec{r} - \vec{r}')$$ and as such we can recover the form ##\nabla \cdot \vec{E} = \frac{\sigma}{\epsilon_0}##. The potential is also logarithmic, $$V(r) = -\frac{q}{2 \pi \epsilon_0} \ln{\frac{r}{a}}$$ where ##a## is an arbitrary constant of integration.
Anyway we should probably wait and see if this was what @Vanadium 50 was referring to before speculating any further :wink:
  • #57
I think ##\oint \mathbf E \cdot dl ## will not be a finite quantity.
  • Skeptical
Likes etotheipi
  • #58
Note that it is not ##\oint \vec{E} \cdot d\vec{l}##, the unit vector ##\hat{n}## points away from the instantaneous centre of curvature. And in any case, the charge enclosed by a closed curve at a radius ##r## from the centre of the ring (outside the ring) is finite, so the field outside the ring in the 2D universe is surely also finite.
  • #59
Not exactly - that would change Coulomb's Law as well. I think that's what etotheipi's paper is about. I am not changing Coulomb's Law. However, I am working strictly in a plane. Because that's what the problem said to do. I would not call it an infinite cylinder because I don't know what the role of λ would be in that geometry.
I'm not doing anything but what the problem says. The problem says to neglect the thickness, so I am working with a zero thickness line. But what I am hearing is "No! The line has cross-sectional extent!" and "No, he's really talking about an infinite cylinder!" and now even "He must not be using 3-D Maxwell's equations!"
This feels kind of like an ideal gas problem, and having everyone saying "Any real gas would have liquified!" I have answered the question asked. I have not tried to answer a "better" version of this question.
Likes etotheipi
  • #60
Well, I meant our contour is the loop itself and that's where field is not finite.
Likes etotheipi
  • #61
Let me explain what I both understand and don't understand about the field line approach you propose (I'll go back to a 3D universe :wink:).
The number of field lines through a surface that encloses the ring is a measure of the flux out of the surface, and is proportional to the enclosed charge. So if we make the ring smaller but maintain its charge, the number of field lines through any surface enclosing the ring will not change. This is okay 😁.
But what I am struggling to understand is why that implies the field just outside of the ring in the radial direction is ##\frac{Q}{4\pi \epsilon_0 r^2}##, at a distance ##r## from the centre. That appears to only be the case if we have spherical symmetry. You did mention that you were only considering field lines in the plane, but I'm not sure this is valid since we are still applying the 3D theorem of Gauss.
Indeed I tried finding an explicit formula without heuristics and ended up with some horrible integrals that I could not solve, which seemed to imply to me that the radial field outside of the ring did not take such a nice form.
I wondered if I had misinterpreted anything you said?
  • #62
Make the ring as small as you can. It is now indistinguishable from a point. Now use the field from a point.
  • #63
What about this; I found a reference that deals analytically with the electric field from a ring of charge like the one we are describing, and the radial electric field at a point P at ##\vec{p}## does not look like it obeys the relation you suggest, but instead the horrible expression requiring elliptic integrals
where terms are defined in the paper http://www.mare.ee/indrek/ephi/efield_ring_of_charge.pdf
Likes Delta2
  • #64
If you read the paper, you would see that he is discussing the field in the XZ plane, not the XY plane. It is possible that if you took the appropriate limit of his calculation you would get an answer different than mine, but I think that's your responsibility to show that. Otherwise, you can deluge me with a bunch of random calculations on random webpages and say "Ha! Prove that this calculation's limiting case matches your derivation" without end.
  • #65
I thought the point was that because of the symmetry of the ring, we can describe the situation with no loss of generality by positioning the ring in the XY plane and the test charge at an arbitrary point in the XZ plane. For instance, positioning our test charge along the ##y## axis would be equivalent to putting it along the ##x## axis and rotating our piece of paper. The benefit is that we now only require two coordinates.
In any case, we are looking at the specific case in that paper where ##a=0## and ##r>R##, where the terms ##q## and ##\mu## in that formula for ##E_r## are defined as ##q = r^2 + R^2 + a^2 + 2rR## and ##\mu = \frac{4rR}{q}##. At first glance, it doesn't look like that yields a Coulombic field strength for ##E_r##.
I only provided this reference as a counter-example because I am still struggling to understand how the heuristic shrinking of the ring can imply your expression. I have not checked their calculations, however, so I cannot vouch for its accuracy.
  • #66
The field is infinite at the ring in one case and finite at the other case, i don't understand how the field configurations are equivalent. Counting field lines i found them infinite at r=R in one case and finite at the same location in the other case where the charge is in center.
How do we call the center of the circle that corresponds to the ring?
  • #67
I am working only in the XY plane. I say it over and over and over again.
If you want to take an XZ calculation and see what happens when you set z = 0, I think it's your responsibility to do that. You can't just toss calculations at me for something else.
Are you talking about at each side of the ring? I want an answer so I pick the side that's finite.
  • #68
I think this is actually the problem. We are considering a ring embedded in a 3D space. As such, we must use Maxwell's equations in 3D. So it is impossible to "strictly work in a plane" in the sense of your heuristic argument with field lines.
As an example, here is my proof of the shell theorem. Take a spherically symmetric charge distribution, and a spherical surface ##S##. Then$$\int_S \vec{E} \cdot d\vec{A} = 4\pi r^2 E = \frac{Q}{\epsilon_0}$$hence the configuration is equivalent to a point charge at the origin. The key stipulation here was the spherical symmetry, since that allows us to remove the electric field from the integral i.e. it is of uniform magnitude across ##S##.
Now for a ring of charge, we can also surround it by a Gaussian surface and write $$\int_S \vec{E} \cdot d\vec{A} = \frac{Q}{\epsilon_0}$$except now we cannot deduce anything further because there is not sufficient symmetry. Although the flux/number of field lines ##\int_S \vec{E} \cdot d\vec{A}## is indeed constant however you choose your surface, that does not imply shell theorem for a ring, because we can no longer pull ##E## out of the integral: it is not of constant magnitude over ##S##!
In your terms, as you make the ring smaller and smaller, we are actually changing the distribution of field lines. We can thus infer nothing about the magnitude of the field strength outside the ring.
  • #69
Which is what I explicitly said I was doing in #59.
I discussed this when I said 'People are, often implicitly, interpreting "negligible thickness" as "the ring is a torus, and we are taking the limit as the minor axis goes to zero.' As I pointed out then, doing this leads to infinities.
Let me point out that I am the only person who has actually been able to get to an answer to this problem.
The complaints fall into two categories. One is "you need to consider a finite extent of the ring (aka 3D vs 2D)" where my response has been that I am following the question as asked. It says "negligible" so I am neglecting it. (And would argue that not neglecting it when told to is a mistake) I have been very explicit about it. The other objection is that in a case with ambiguity ("inside" or "outside" of the ring) I pick the finite answer. I have been very explicit about that as well.
I've said all that I intend to say. This is the answer to the question posed. It is not an answer to any different question, even if that question is "better" or more realistic.
Likes etotheipi
  • #70
Alright, thanks for your help. I still do not think that the field outside the ring is ##\frac{q}{4\pi \epsilon_0 r^2}##, although I would agree that the field reduces to this in the limit ##r \gg R##. I don't think either of the shell theorems apply to rings in a 3D universe.
So perhaps we will agree to disagree :wink:. You did manage to get an answer, though, but I think I am happier not having an answer than accepting one that I don't understand. In any case, an interesting discussion!
