What Is the True Nature of Energy?
  • Thread starter JJBladester
  • Tags
    Energy
In summary, energy is the ability to do work and is a prerequisite for force. It can take different forms, such as gravitational potential energy, electrostatic potential energy, and kinetic energy. Energy is also the source of the gravitational field and is measured in various ways. However, the exact nature of energy is still not fully understood and is a subject of ongoing research and debate, as described by physicist Richard Feynman.
  • #176
In reply to Putnam's post #85, and most of the following discussion since,
I likened energy to money as an abstraction. JamesA.Putnam did not like it...
JamesA.Putnam said:
"Energy is like money? I read the earlier messages. Money is real. It can be held. It can be contained and tested for its physical effects. It is physical effects that concerns physics. Do we know what energy is or do we not know what it is? Likenesses, meaning analogies, do not count."
You missed the point James! Firstly, the analogy with money is only to aid understanding, most analogies are never intended to be exact correspondences, if so we wouldn't call them analogies. Besides that, JaredJames picked up the essence of the analogy well when he noted that "money doesn't exist"...you cannot say coins and dollars define money because while it's true they are forms of money, that doesn't cover many, many other forms of money, as JaredJames pointed out. This is again analogous with the confusion so many people have, when they think they have a definition of energy as a concrete reality, someone comes along and easily disabuses them of the notion because it cannot cover all forms of what we refer to as energy in physics. The work=energy definition is an example. It is not a sufficient definition. Just like coins are not a sufficient definition of money.
So, in short, the money analogy was never intended to "count" as a definition. The definitions of energy pertaining to relative states of systems and time translation symmetry are probably the best you are ever going to get, since, I submit, they cover everything that is considered "energy" in modern physics. It agrees with the use of the Hamiltonian in QM as the generator of time evolution. Furthermore, the relational definition is precisely what you are looking for when you say you are concerned only about the physical effects. It is indeed the relationships that count, and pretty much only relationships that ever count, all else is unnecessary add-ons (I claim, I'm not saying I'm an oracle who knows all ;-)
Aside: there are even recent attempts to place the foundations of quantum mechanics and quantum gravity on a purely relational basis (eg., http://arxiv.org/abs/quant-ph/9609002). That's not addressing the "what is energy?" question directly, but if the ideas have merit and become mainstream it would do a lot to ease future physics student's qualms about the question 'what is energy?'.I'll reiterate a bit more:
It's dopey to say energy is force times distance or capacity to do work, since that doesn't cover many forms of energy like heat energy with zero free energy and so forth. My plea is to realize how we use energy in physics. You should soon convince yourself that it is a relationship between states of a system, so it's purely an abstract concept, which BTW explains why there is all the confusion when folks think about trying to grasp and touch the stuff, or try to define it in concrete terms, you can't! Or if you do, you will find that you've only got a partial definition that doesn't cover other forms of energy.
  • #177
I likened energy to money as an abstraction. JamesA.Putnam did not like it... ...(Putnam's dots to show that I deleted much of the quote.)...
I don't have strong feelings about the money analogy. I do prefer more direct answers, but, analogies can certainly be useful, so, for me, yours stands for what you explained it to be. I could do without the 'dopey' description. I would have stated it as "...energy is force times distance or capacity to do work... is a mathematical description. We don't have a physical description outside of patterns of effects. Heat is energy intransit, so I am not clear on your point of separating types of energy. I could use a little friendly further explanation of your point with regard to the zero free energy reference. I am willing to learn because I am driven to learn. It is just that I don't need to learn new words for expressing the same thing. I am not saying that you do this. I am only requesting that explanations delve into the actions of physical properties at least to the extent that they are presently known.
  • #178
James,
You never responded to my post #158 ... would you care to?
  • #179
SpectraCat said:
No it is not. Energy is a path independent state function of a system. Work is a path-dependent quantity, and in fact is only defined in terms of *changes* in energy between two systems. That's why we define energy as a measure of the capacity of a system to do work.
What's more, the work done moving a mass from point a to point b is NOT a fixed quantity. The difference in energy between that mass when it is at point a and when it is at point b *is* a fixed quantity .. that is why we call it a state function.
SpectraCat, I missed this one: Energy is not path independent. It is true that the final calculation of the sum total of force times distance is path independent. However, all along the path followed by force times distance, the calculation can be made instantaneously and that sum total will be energy. So the change in energy follows the path of force times distance. It is only the use of two different words that makes energy as the final sum total path independent while its word susbstitute work is acknowledged to be path dependent. In any ncase, you used the word capacity. What is capacity that it should clarify the cause of change of velocity?
Your second point, I think, is clarified by my same answer. So long as vector type changes of direction are taken into account, work can vary wildly and so can energy. It does remain the case that final results are independent of the path taken on a generalized work diagram. If, I make instantaneous calculations of sum totals continuously during the path traveled, I might even say, a generalized energy diagram. However, formally speaking, keeping to separate terminologies, your point is well taken. I am not so interested in the debate about whether the word work or the word energy is more textbook appropriate for a given circumstance as I am interested in the cause of changes of either. That cause must exist but no one knows what cause is. Until cause can be explained, we are only speaking about effects. If energy is only another word for specific effects, then, I find the position that effects can be convertible into matter to be incomplete. Perhaps this point is viewed here as a separate subject. Thank you for your message. Any corrections you have to offer to my opinion are welcome.
  • #180
Yes, it is. It is a state function. The amount of kinetic (or potential) energy a body has is determined only by its state at the time of measurement ... the past history of the body is irrelevant to its energy. As you can see, the integral of "force times distance" is most assuredly NOT independent of past history .. it is *defined* by past history. The quantity represented by the integral of "force times distance" is called work in physics. Work is a *change* in energy of a system. In order for a system to do work on its surroundings, it must end up with less energy than it started with. This is why we say that energy is a measure of the capacity to do work.
Now you are perhaps getting the idea .. that last statement is close to correct ... work is the *PATH-DEPENDENT CHANGE* in energy as a force is applied to a system over a particular path. If you have two well defined states of a system, the energy difference between those two states will also be a well-defined quantity. However the work required to move the system between those two points is NOT well-defined until you have specified a path (i.e. a trajectory where the position and force vectors are specified at every point).
You seem to think this is all just semantics ... it is not. Energy and work have the same units, but they are not interchangable concepts for the reasons I gave above.
  • #181
Hi again JamesP, SpectraCat et al., "once more unto the breach dear friend,..." and maybe a few more times after this.
Replying to JP's point:
"Heat is energy intransit, so I am not clear on your point of separating types of energy."
My point is that energy clearly exists in different forms, kinetic and potential and work, and then as an eigenvalue of an operator in QM formalisms, etc., etc.. None of these forms of energy suffices in itself as a definition or explanation of "what energy is". So, my point is that to seek an explanation for "what energy is" in any particular form, such as the Work theorem (which is just a definition of Work in terms of other observables, and hence is a relational concept, it is not a definition of energy) is futile. You'll never pin down energy that way. To be fair, I haven't defined or attempted to definitively answer the original question posted by JJBladester. All I've attempted is an argument for why a rational physicist might realize or accept that our current concept of energy is a pure abstraction, an abstraction nonetheless that has immediate and motive physical consequences---it provides a framework for doing physics, viz. the Hamiltonian formalism of classical mechanics and the operator formalism of QM. And an abstraction nonetheless that can be crisply and unambiguously defined in various forms, unified, I think, by the notion of time translation invariance in CM and time evolution in QM.
If you look at his JJ's post, he provides a few examples of types of energy. So I rest my case on this point---that there are multiple forms of energy, none of which can or should be taken as a universal definition, though each is fine and clear as a definition of one form of energy in the given context & scope intended (which isn't always spelt out, which may add to some of the confusion about this topic).
Even the "energy as a measure of the capacity of a system to do work" definition is incomplete. As you picked up on JP, there is also "free energy". And a system with zero free energy does not have a capacity to do net work! So once again, we see an attempt to wrap things up with an all-encompassing definition of energy based upon one form or use of the concept of energy which fails.
Note, free energy = 'the energy in a physical system that can be converted to do work'.
So when a system has zero free energy, such as a gas that has reached thermal equilibrium, or a dead battery, then there is no capacity to convert energy to work, and yet the system (pick one) is clearly not at absolute zero temperature, so it still has heat energy. But talk to the experts on thermodynamics for further elaboration, since thermodynamics is not my particular specialty.
Next, JP wrote:
"I am not so interested in the debate about whether the word work or the word energy is more textbook appropriate for a given circumstance as I am interested in the cause of changes of either. That cause must exist but no one knows what cause is. Until cause can be explained, we are only speaking about effects. If energy is only another word for specific effects, then, I find the position that effects can be convertible into matter to be incomplete. Perhaps this point is viewed here as a separate subject."
This is an interesting turn in the discussion, well worth exploring.
I may be out of my depth now, but I would suspect that physics does not seek to inquire into ultimate causes, even though naive physicists and even professionals slip into imagining they are delving into causation from time to time---I think that's a conceit and a delusion, but that's just MHO. "We" (the collective Borg ;-) gave this enterprise (seeking ultimate causes) up once "we" accepted the least iota of quantum indeterminism. Modern physics seeks only to inquire into fundamental laws, and seeks to uncover the most parsimonious laws needed to describe physical phenomena. How can we ever hope to deduce ultimate causes? I for one don't see how it is possible, but maybe I'm philosophically too unsophisticated to see something obvious here?
In other words, IMHO, although I think your (JP's) desire to want to know the causes of the changes in state of a system that require energy principles to explain them, is admirable and worthy, I do not think it is a physics problem. Feel free to argue otherwise, I'd be interested...
The physics problem is to find mathematical laws that predict the changes in state. The only physics answer I suspect is circular, which is not a bad thing. We use energy to predict changes in state or relational states, and energy is defined essentially as a predictor of changes in state. (More or less that's my overly crude summary of what physicists can say about causes.) The physicist is merely a tinkerer who tries to nudge the mathematical relationships to get the predictions conforming closer to observed reality. Seems like kind of a let down huh? But it needn't be viewed that way, just look at the triumphs of technology and blisteringly beautiful mathematics that such endeavours have spawned. To seek anything more from physics is probably akin to a god-delusion or god-complex, where physics is god. I for one don't want to go there.
You might as well just say that the machine masters that run our universe are the cause of these relationships and laws that we uncover. I think physics can only uncover the relationships, it cannot say much about ultimate causes. Whether you've agreed that energy is an abstraction or not, this I think is nearly the end of the road for a physics forum on the topic. While I admire the desire to want to know the ultimate causes of things, as a physicist I think one has to ultimately settle for a mathematical description. That needn't forbid philosophers from wondering about why the description must be such as the physicists discover. But it's a different game. Not a bad one, but different.
Here's another spanner in the works: who said causes must exist? If we live in a Multiverse of the type outline by Tegmark and others, then it is dumb blind luck that the laws and rules physicists uncover continue to be stable and seem to be consistent. There is no cause of things in a Multiverse, only patterns that can be treated by sentient beings observing them as causal. In a true Multiverse this is a delusion. I myself do not subscribe to such metaphysics, but I would find it hard, maybe impossible, to deny Tegmark his suppositions. Maybe he is right. I can't disprove his grand theory. My only pointer being that physics is on a very tenuous ground when it attempts to pronounce that there are known causes of phenomena. The sagacious physicists would probably prefer to just say, "this here <insert formalisms> is how I define energy, these are it's implications <insert consequences> and the causes of these relationships are metaphysical, not scientifically accessible."
I know that sounds like giving up, but it is not. It is merely demarcating the boundaries of what we scope out as "physics", separate from metaphysics and philosophy & ontology.
Could I just add: I think a lot of people get this confusion about physics. They look to physics for ultimate answers, which is a sort of conceit or prejudice of our modern enlightened scientific age, which has achieved so much for us technologically, but in real terms has done nothing to explain the "why" of the universe in anything other than purey abstract mathematical-relational terms.
Looking to physics for knowledge about ultimate causes is I think a fine pursuit and one that humanity should pursue. Indeed, this is one of the greatest things about physics---it reveals to us knowledge about causal structures, or at least the apparent causal patterns. But thinking that physics will provide the actual answer to the ontological questions of "what the causes are" is naive and I think a fore-doomed quest. And dare I use another analogy (only for helping colour my argument you understand!): imagine the inside of the proverbial elephant is an eternal black hole, so we cannot ever observe it's internal structure, but we can see it's outer form, which looks just like an elephant. Physics (the human scientific enterprise) stands kinda' in relation to our universe like an external observer trying to understand what makes the elephant tick, where the elephant is the universe, its' skin and air and tusks are what we can observe, and we are some sort of insects or bacteria living in it's skin desperately trying to understand it's behaviour and innermost laws.
Sorry if this poor poetic analogy doesn't satisfy ya. I'm doin' my best. you'll have to interpret further for yourself and maybe ask for more clarification about what I'm trying to say...unless you think I'm nuts---in which case ignore my ramblings.
  • #182
I don't have to try again to get it right. I just need to try again to communicate that the word work is a stand in for change of energy.
No, you need to find a credible reference which actually agrees with your position. So far you have not been able to find any credible reference which defines energy as force times distance. Here is another source which contradicts your position: http://en.wikipedia.org/wiki/Work_(physics) it says W = f.d and that W = ΔKE. Therefore, by substitution f.d = ΔKE ≠ E.
Consider an object of mass 1 kg initially moving at 1 m/s in the absence of any external force. According to your definition, E = F.d = 0.d = 0, which is in contradiction to the actual kinetic energy of 1/2 J. If the mass collides with another mass then it can exert a force of 1 N for a duration of 1 s, during which it will have traveled a distance of 1/2 m. Thus the mass has the capacity to do F.d = 1 N 1/2 m = 1/2 J of work, in agreement with the standard definition of energy as the capacity to do work and in agreement with the actual kinetic energy of 1/2 J.
Now, consider other forms of energy. For example, consider an electron at rest in the absence of any external force, which has a mass energy of .5 MeV. Again, according to you E = F.d = 0.d = 0, which is in contradiction to the actual mass energy of .5 MeV. The electron may be anhilated producing a photon which can do .5 MeV work on any charged particle, in agreement with the standard defintion of energy as the capacity to do work and in agreement with the actual mass energy of .5 MeV.
Your definition is not just a different way to say the same thing, it is wrong. It is not supported by the two references you cited, it is contradicted by all of the references I have cited, and it demonstrably fails in the two examples shown above.
  • #183
First of all, KOSS, thank you very much for the time and effort you put into your thoughtful post. I read it twice through.
Ultimately, as I've stated before, energy describes the state of a system or the state of two or more interacting systems. Energy is a quantity that tells us what is happening (in terms of movement) or what could happen if things change. When I say "things change" I am referring to the position of certain matter with respect to other matter or a change in the velocity of one or more pieces of matter.
When you say "God-delusion," I am saddened that you must think that way. You put faith in physics. You don't know that in another few years a new theory will shatter our existing "knowledge". You don't know that the sun will rise tomorrow. "Now faith is the substance of things hoped for, the evidence of things not seen." This is from Hebrews 11:1. In other words, God is not explained by physics. Yes, physics is evidence that we, as humans, are making imminse progress. However, and I think you and everyone else will agree, we don't know the root cause for everything, particularly energy.
At any rate, regardless of your origin or religion, we do physics because curiosity demands it. That is the bottom line for me. I need to know, thus I find it valuable to spend my time studying and pondering the inner workings of this amazing and beautiful world.
Perhaps in doing so, we can make our neighbor's life easier. Perhaps we find a certain thrill that we can't quite explain. Physics is just cool to us and thus we are bound to it.
... And you're right, KOSS, physics is not God. God is God. If we were God, we would know the cause to everything as JP is hoping for.
  • #184
There is no problem in seeking answers. However, there is a problem in not listening when an answer is given to you.
No, we don't know what theories will appear in the future, however I will gladly accept the new theory provided there is sufficient evidence.
The search for a "root cause" of everything is futile. One can always ask "why". And what does god have to do with this? Please, leave God out of this.
  • #185
I have listened and I have thought about every post to my original question, 'What is energy?" There is no problem in my interpretation of what energy is according to the responses to the original question and my own seeking. Understand that it is okay to be both a physicist and a Christian simultaneously.
You seem very black and white.
  • #186
This is the vacuum thread all over again.
We have energy, a clearly defined term in physics and we have people arguing the definition is wrong.
In the vacuum thread we had a clear definition and people arguing it was wrong because it didn't include EM radiation. Which is nonsense. What they were discussing was a different issue.
This is identical to what is happening here. Just because you arent happy with the physics definition, doesn't mean anything.
  • #187
No scientist has "faith" in science, we accept the conclusion that the current evidence shows. It's easy for people to mistake what scientists say as absolutes but in reality anything said is with the caveat "to the best of our knowledge...". You might want to look up the relativity of wrong (from which my signature comes from).
The fact that we do not have a thorough understanding of the formation of the universe does not mean we cannot define energy and certainly does not mean it's logical to slot god into the unknown
  • #188
first let me say thank you for asking the question you did in the first place. most would not. i too am not content with the current understanding of "energy"
currently i believe it to be a result of the relationship between space and matter. the flip side to that model is that time is also a result of that relationship. I am not sure if my own belief will help u but it does help me hold the universe in my head.
interestingly the post which stated that gravity is the root of energy is directly in line with this model. if you would like me to elaborate i will. but i don't want to be out of line and de-rail your thread.
  • #189
I would like to remind everyone of the rules that we each agreed to when we signed up. There are specific sections on overly speculative posts and on religious discussions. Please click on the link labeled "rules" at the top of the page for details.
This site is for discussing and learning mainstream science, not for promoting personal theories. The mainstream definition of energy is the capacity to do work.
  • #190
Energy is simply the readiness for a body to assume an assignment over a distance in an time determined by the will called the force and manipulated/controlled/overseen by gravity/friction.
  • #191
Koss,
A very well written and helpful answer.
"While I admire the desire to want to know the ultimate causes of things, as a physicist I think one has to ultimately settle for a mathematical description. That needn't forbid philosophers from wondering about why the description must be such as the physicists discover. But it's a different game. Not a bad one, but different."
Actually my point was that we do not know what cause is. It was not a question where I answer it or anyone else needs to answer it. I brought that point up to make clear, my viewpoint, that definitions such as 'force is influence' are unhelpful. The answer, as I see it is that 'we do not know what force is'. I see no problem with recognizing that which is known versus that which is not known. Effects are known. Cause is unknown. My own response to 'What is energy?' is that the answer depends upon explaining force, but, we cannot explain force. Therefore, I added to the discussion, in effect, that we do not know what energy is. I still see no value in debating that the acceleration of a particle who's energy is constantly in existence and changing according to the sum of differential values of force times distance, is really not a measurement of energy. If the book answer is different, let the book answer rule. As for me, I will continue to look beyond answers that are formed from mere exchanges of words.
Thank you for taking the time to write a detailed informative message.
James
  • #192
Addressing this in particular: "As you can see, the integral of "force times distance" is most assuredly NOT independent of past history .. it is *defined* by past history. The quantity represented by the integral of "force times distance" is called work in physics. Work is a *change* in energy of a system. "
I would appreciate your view on this: The integral of force times distance is independent of past history. That is why a constant force can be substituted to represent all examples of force times distance. That is why a constant force can be used to derive Einstein's energy equation.
"Now you are perhaps getting the idea .. that last statement is close to correct ... work is the *PATH-DEPENDENT CHANGE* in energy as a force is applied to a system over a particular path. " I think I have the idea. Still, I would be interested in your explanation about why a change in energy is not a recognized as simply a change in energy, but rather, work?
I put forward the view that energy and work have the same units because they are the same thing. Any differences are semantical. The introduction of the word 'capacity' for purposes of mediating between the two is, from my viewpoint, semantical. Still, if the book answer must be that they are different things, then let the book answer rule. However, they both result from the integral of force times distance and they both suffer from the unknown nature of force. Is there an instance where work occurs that I cannot equate every step, even infintesimal steps, with the existence of energy?
I gave my contribution to this thread in a few earlier messages. If my explanations for my views are unacceptable, I don't need to push them, presenting them is enough. I do welcome input from others and I thank you for your explanations.
  • #193
This is not correct. The fact that in general [itex]E\ne \Delta E = W[/itex] is not merely semantics. They are different quantities, not the same quantity by different names.
No, but there are instances where energy exists that you cannot equate with the occurence of work. I gave some specific examples above.
  • #194
DaleSpam said:
This is not correct. The fact that in general [itex]x\ne \Delta x[/itex] is not merely semantics. They are different quantities, not the same quantity by different names.
Thesum total is energy and the change is a change in energy.
I don't think that I am required to equate all examples of energy with work. Work is a name for a specific event. That event is a change in energy in specific circumstances. Those circumstances do not cover all examples of energy. In other words, the word energy will always apply while the word work is a limited substitute applied to a limited set of circumstances.
I did respond to your earlier message, but, I must have missed pushing the right button or perhaps it just got lost in cyberspace. Anyway the jist of my message was that I am retracting my shorthand description of energy is force times distance for my clearer statement that energy is the sum total of force times distance.
  • #195
Then it cannot be the definition of energy. The definition must cover all examples or it is not the definition.
I understood that to be your meaning and the counter examples in post 182 disprove your definition.
  • #196
No it doesn't.
For me, your examples cited showed that you did not apply my intended meaning. The examples were clearly erroneous. Furthermore, a sum total exists between any two points. Even if those points are infinitesimally close, the sum total of the difference between those two points is still a sum total. Differential quantities of energy are not inherently different from accumulations of differential quantities of energy. The examples you cited do not represent disproval of my definition.
  • #197
Then show clearly the error. Apply your definition of energy to an electron at rest in the absence of any external force and show how you get the correct mass energy of .5 MeV and where I made my mistake in using your definition to get 0.
  • #198
The error was that you repeatedly included a zero value for force on the basis that my position is simply that energy is the simple product fxd. You substituted zeros into that simple equation as if it was a valid disproval of my position. Zero force in those examples mean zero energy. I never intended that and I am not being that silly. I say that the calculation of energy exists for any calculation that can be called work. I say that, in general, energy is the sum total of force times distance between any two points. I say that units of measurement belong always to the same property. I would appreciate your view on that last sentence.
  • #199
What other value besides 0 could I possibly put in for force in a situation with no force? I am only using your definition as you have stated it.
If you feel that I worked them out incorrectly then kindly work out the two examples I posted in the way that you intended your definition of energy to be used.
  • #200
Did you change your message? I quoted you but the quote missed including the electron at rest question. Just wondering if I am doing something wrong in creating these posts?
An electron can exert force for an unknown reason. If there is nothing to exert that force upon, the nature of the electron is not changed. So far, the discussion involves differentiating between work and kinetic energy. I see no work performed by an electron that has nothing to exert its force upon. However, the electron retains its ability to exert force upon another charge particle should that circumstance occur. The page I am on now doesn't show your original message. I will end this message and again look up your previous message.
  • #201
Sorry about that. Yes, I did change my message. I try to do so quickly after posting if I make a change, but sometimes not quickly enough.
In other words, the sum total of the work done by the electron is 0, but it has the capacity to do work. :smile:
  • #202
I did write a reply, it got lost. I am going back to reply again. However, I do not understand why you insist that the sum total of force times distance can only be calculated as an instantaneous event. In other words, zero force means energy does not exist. Obviously energy exists as the sum total of force times distance for a previously applied force that may not now be active. Why do you keep insisting that my argument is that kinetic energy disappears if a force is no longer active?
  • #203
In other words: An electron can cause another charged particle to acquire kinetic energy. Here again is that word capacity as if it removes energy from the example. Is capacity another word for force or not? I miss the empirical significance of the need for introducing the word capacity.
  • #204
Sorry I was not clear. By "absence of any external force" I meant that there is not now any force nor has there ever been any force acting on the mass/electron. I understood that you intended it to be a sum of previously applied forces so I set up the example in the complete absence of forces.
  • #205
"Capacity to do work" means that the system may currently not be performing work nor have ever performed work but it retains its ability to do work should the circumstance occur. It is just what you described above for the electron.
Similarly, if a bottle has a 1 L water-carrying capacity then it may currently not be carrying water nor have ever carried any water, but it retains the ability to carry 1 L of water should the circumstances occur.
  • #206
Ok. So you are saying that the electron is brought into existence without needing the application of force. I am not a physicist, but, I find that condition to be subject to debate. However, let's assume there is an electron as you stated and we know of no history of force being applied. I have no problem with that condition. The electron is the source, the cause, the exerter of force. Force begins somewhere before it is applied. I allow for charged particles to represent force without explanation. As I have stated in previous messages, we do not know what cause is and that includes me. I do not know what cause is. I only know what cause does. I do not have an explanation for the origin of cause. Personally, I think that charged particles can be accepted as known causes. Any attempt to explain the origin of their force would require explaining electric charge. I could speculate, but that is not appropriate here. I simply allow for force to exist before it is applied. Its existence is not dependent upon its application. An electron can exert force. I do not know why.
  • #207
I don't see how else you could word that sentence and include "energy" or "force" instead of "capacity".
  • #208
Why not just say it has energy? Kinetic energy of an object is the result of applying a force across a distance, and, the carrier of that kinetic energy can apply force in turn? Yes the object has the capacity to apply force, but, the introduction of that word does not clarify the physical circumstances. Both force and distance are included in equations. Capacity is not inculded in equations. In any case, even if my view does not suffice for others, I still see words exchanged for words instead of sticking to that which we know of as empirical evidence. What we know empirically is that changes of velocity occur for unknown reasons. Fortunately, we do not have to actually know those reasons in order to set up conditions that make certain patterns in changes of velocity useful to us.
  • #209
James
Isn't this like the whole point some of us has been trying to make? Science has specific definitions and meanings for everything. If you don't agree then you don't agree and there isn't anything we can do about that, which is fine. However if you are going to argue on Physics Forums, then you cannot say that science is wrong and expect to be taken seriously. YOU may say that it is not known what causes force or something, but according to Science there IS a cause. Don't misunderstand me, I completely recognize and agree with your point of view in that we don't know the "cause" of some things. Attempting to discuss that takes you beyond current mainstream science which is not something generally allowed here at PF because, as you can see from this thread, it typically gets out of hand.
  • #210
My view on that is that it makes no sense at all .. at least not how you have stated it. First of all, let's look at the actual mathematical derivation of work, because the phrases we have been using to describe it (i.e. force times distance or even the integral of force times distance) are imprecise at best.
The equation for work is: [tex]W_C=\int _C\vec{F}\cdot d\vec{r}[/tex]
What that integral means is, "The work expended over some arbitrary path C is the integral of the dot product of the force vector and the infinitesimal change in the position vector along all points on the path C." That is what I meant when I said you can't even calculate a value for work until you know the path that was taken. This is to be contrasted with the difference in energy between starting and ending points of that same arbitrary path C. That energy difference is a STATE FUNCTION! It always has the same value whether you take path C, or D or XYZ. That is why although work is a change in energy, and has the units of energy, it is not the same thing as energy. Seriously man, if you don't get this, just look at the thermodynamics chapter of your physics textbook, or even a decent college level chemistry textbook .. it will verify what I am saying and give more carefully constructed examples.
I have no idea what you are talking about when you mention "constant force" or "einstein's energy equation". Are you talking about E=Mc[sup2[/sup]? Because I am pretty sure he didn't use any sort of idea about "constant force" to derive that.
I explained that above ... and I have explained it many times. I can only conclude that you don't understand what a state function is, and why a state function is different from a path-dependent quantity.
Sorry, but that is simply wrong, at least from the standpoint of physics. I and many others on this thread have tried to explain to you why it is wrong. If you don't understand our answers, perhaps you should take it upon yourself to do some more careful reading to better understand why what we are saying is correct.
No there is not ... that is because work always involves a change in energy! On the other hand, changes in energy do not always involve work. In thermodynamics, the energy change for a given process is defined as the sum of heat and work exchanged. in that process. If no work is done, then the energy change is due ONLY to the exchange of heat. If the process is adiabatic (i.e. no heat exchanged), then the energy change is due only to the work expended during the process.
