B What is the use of simplifying a question in math?
Simplifying mathematical expressions, such as trigonometric identities, enhances understanding and facilitates comparisons and further calculations. For instance, transforming Sin(x) * Cos(x) into Sin(2*x)/2 provides a clearer representation, especially when graphing. While both expressions yield the same results, the simplified form is often preferred for ease of use in future problems. The discussion emphasizes that simpler forms can prevent errors in calculations and improve visualization of graphs. Ultimately, simplifying expressions aids in achieving a more intuitive grasp of mathematical concepts.
pairofstrings
Hello. I have been looking into trigonometric identities that helps to simplify a question in mathematics. But the question that I have is, why do I need to simplify a question?
For instance:
Sin(x) * Cos(x) means Sin(2*x)/2.
I have no answer that tells me why I simplify Sin(x) * Cos(x) to its corresponding answer.
I have plotted graphs of Sin(x) * Cos(x) and Sin(2*x)/2 and both the expression give the same result.
I request you to write all the words associated with this question.
Thank you.
Mathematics news on Phys.org
Double-angle formula
Simplifying the result makes it easier to understand it, it makes comparisons easier, and it is easier to use it in further steps if it is not the final answer.
The question "what is the nicest answer" is not always easy to answer. It is obvious that ##\displaystyle \left(\frac {3\sin(x)}{2} - \frac {\sin^2(x)}{2\sin(x)}\right) \left(\frac {4\cos^2(x)}{3\cos(x)} - \frac {\cos(x)}{3}\right)## is not a proper final answer, although it is identical to your expression, but sin(x) cos(x) versus sin(2x)/2? I would prefer sin(x) cos(x) over sin(2x)/2 in most cases, unless the double angle (2x) appears elsewhere as well.
Likes pairofstrings and FactChecker
In my experience it is better to put it in the simplest form for ease of future solutions or graph plotting.
For example say you are asked to plot the long trig expression mfb posted within a certain range and you don't have a plotter. So you are to use excel or some similar spreadsheet program. And if you simplified the expression, it might be something like (it is not though) sin(9x)cos(3x).
In excel, I'd find it easier to plot sin(9x)cos(3x) than the long expression where I am likely to make a mistake and thus get the final solution wrong.
Likes pairofstrings
Looking at the sin cos expression its hard to picture its graph but looking at sin 2x I know immediately that it will look like a sin x graph but with a doubled cycle in the domain of 0 to 2pi
Its the same reason for recasting a linear equation into y = mx + b form so that you can get the y intercept and the slope immediately and can draw the graph.
Likes pairofstrings
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
