What is the value of $xy+yz+zx$ in a system of equations with real numbers?
  • MHB
  • Thread starter anemone
In summary, the value of $xy+yz+zx$ cannot be determined without more information and depends on the given system of equations and values of $x$, $y$, and $z$. To solve for this value, you need a system of equations with at least two equations and three variables, and can use substitution, elimination, or other algebraic methods. The value of $xy+yz+zx$ can be negative depending on the system of equations and values of $x$, $y$, and $z$, and there is no specific formula for calculating it. The value of $xy+yz+zx$ can change as the values of $x$, $y$, and $z$ are varied in the system of equations
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
If $\{x,y,z\}⊂\Bbb{R}^+$ and
$x^2+xy+y^2=3\\y^2+yz+z^2=1\\x^2+xz+z^2=4$,
find the value of $xy+yz+zx$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. castor28
2. Opalg
3. kaliprasad
Solution from Opalg:
Given $$x^2+xy+y^2=3, \qquad(1)\\y^2+yz+z^2=1, \qquad(2)\\z^2+zx+x^2=4, \qquad(3)$$ it follows that $$x^3-y^3 = (x-y)(x^2+xy+y^2) = 3(x-y),\\y^3 - z^3 = (y-z)(y^2+yz+z^2) = y-z, \\z^3 - x^3 = (z-x)(z^2+zx+x^2) = 4(z-x).$$ Add those three equations, to get $0 = 3(x-y) + y-z + 4(z-x) = -x - 2y + 3z$, so that $x = 3z-2y$.
Substitute that into (1): $(3z-2y)^2 + y(3z-2y) + y^2 = 3$, from which $3y^2 -9yz + 9z^2 = 3$. Subtract $3\times(2)$ from that, getting $-12yz + 6z^2 = 0$. Therefore $z(z-2y) = 0$. So either $z=0$ or $z=2y$.
If $z=0$ then (2) says that $y = \pm1$ and (3) says that $x = \pm2$. Then (1) is also satisfied provided that $x$ and $y$ have opposite signs. But since the question allows only positive numbers, that solution must be rejected.
If $z = 2y$ then $x = 3z-2y = 4y$. From (2), $7y^2 = 1$. Therefore $(x,y,z) = \frac1{\sqrt7}(4,1,2)$, and finally $xy+yz+zx = \frac{14}7 = 2.$
Alternate solution from kaliprasad:
We are given
$x^2+xy+y^2 = 3\cdots(1)$
$y^2+yz+z^2 = 1\cdots(2)$
$x^2+xy+y^2 = 4\cdots(3)$
Let us consider a $\triangle\, ABO$ with $AB =\sqrt{3}$, $AO = x$ and $BO = y$
Using law of cos we have
$AB^2 = AO^2 + BO^2 - 2 . AO . BO . \cos\, \angle AOB$
or $3 = x^2+y^2 -2 xy \cos\, \angle AOB$
Comparing with $1^{st}$ equation we get
$\cos\, \angle AOB=-\frac{1}{2}$
or $\angle AOB=120^\circ$
Similarly if we take $\triangle\, BOC$ with $BC =1$ $BO = y$ and $CO =z$ and comparing with (2) we get
$\angle BOC=120^\circ$
Similarly if we take $\triangle\,COD$ with $CD =2$ $CO = z$ and $DO =x$ and comparing with (3) we get
$\angle COD=120^\circ$
Now as
$\angle AOB + \angle BOC +\angle COD=360^\circ$
so OA and OD are overlapping and as OA = OD we have A = D
as $AB^2 + BC^2 = CA^2$ we have ABC is a right angled triangle with right angle at B
So area of $\triangle ABC = \frac{AB * BC}{2} = \frac{\sqrt{3}}{2}\cdots(4)$
Another way to calculate area as sum of 3 triangles and each using law of sine
Area of $\triangle AOB = \frac{1}{2} AO * OB\sin\, \angle AOB = \frac{\sqrt{3}}{4}xy$
Area of $\triangle BOC = frac{1}{2} BO* OC\sin\, \angle BOC = \frac{\sqrt{3}}{4}yz$
Area of $\triangle COA = frac{1}{2} CO* OA\sin\, \angle COA = \frac{\sqrt{3}}{4}zx$
Adding the 3 we get
Area of $\triangle ABC = \frac{\sqrt{3}}{4}(xy+yz+zx)\cdots(5)$
From (4) and (5) we get
$xy+yz+zx = 2$
FAQ: What is the value of $xy+yz+zx$ in a system of equations with real numbers?
What is the meaning of $xy+yz+zx$ in a system of equations?
In a system of equations, $xy+yz+zx$ represents the sum of three products of variables. It is often used to simplify equations and solve for unknown variables.
How is $xy+yz+zx$ calculated in a system of equations?
To calculate $xy+yz+zx$ in a system of equations, you must first substitute the given values for the variables. Then, multiply the corresponding terms and add them together to get the final value.
Is $xy+yz+zx$ always a positive value in a system of equations?
No, $xy+yz+zx$ can be positive, negative, or zero depending on the values of the variables. For example, if all three variables are negative, the value of $xy+yz+zx$ will also be negative.
Can $xy+yz+zx$ be used to solve for all variables in a system of equations?
No, $xy+yz+zx$ can only be used to solve for one variable at a time. It is not possible to solve for all variables simultaneously using this method.
Are there any special cases where the value of $xy+yz+zx$ is always zero in a system of equations?
Yes, if one or more of the variables is equal to zero, then the value of $xy+yz+zx$ will always be zero. This is because any number multiplied by zero is equal to zero.
