What is the Velocity Function for a Car Slowing at a Uniform Rate?
  • Thread starter Thread starter Discalculiate
    Function Velocity
Discalculiate
The position of a car that is being slowed at a uniform rate is given by:
s(t) = 25t - 5.25t^2
where s is the displacement of the car from the point at which braking began and t is the
time in seconds after braking began. Find the velocity function for the car, including
its domain.
The answer is v(t) = 25 -11t 0 < or equal to t < or equal to 25/11
I assume I need to find the value of t first, then take a derivative, but I'm not sure
how to get t by itself
0 = 25t - 5.25t^2
5.25t^2 = 25t
and then I don't know what to do.
I may be wrong here, someone correct me if I am.
I think since s(t) is the position of the car, simply differentiating the equation will give you the v(t), velocity of the car with respect to time.
Thus, v(t) = 25-10.5t
I'm not sure how the answer is v(t) = 25-11t
Maybe the original problem was written incorrectly and should have been s(t)=25t-5.5t^2?
Hopefully I helped...
Ohh, thanks!
I think maybe he might have rounded? That's probably it, but I don't know why.
so if v(t) = 25 - 11t
then when the velocity is 0, the car has come to a stop so
0 = 25 - 11t
11t = 25
so t = 25/11
yup. no problem.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
