What is the voltage across an inductor in an LR circuit?
In an LR circuit connected to a 12V battery, the current at 0.940ms is measured at 4.86mA, increasing to 6.45mA over time. The resistance is calculated to be 1860 Ohms based on the steady-state current. The voltage across the inductor is not equal to the voltage across the resistor, as the battery's presence must be considered. The correct equation for the voltage across the inductor involves the term 1 - exp(-t/(L/R)). The solution provided was not accepted by MasteringPhysics due to this oversight regarding the battery's role in the circuit.
xSpartanCx
An inductor is connected to the terminals of a battery that has an emf of 12.0Vand negligible internal resistance. The current is 4.86mA at 0.940ms after the connection is completed. After a long time the current is 6.45mA.
V = IR
V(t) = V0 (exp(-t/τ))
At infinite time, an inductor appears like a wire. Therefore, 12V = 6.45mA * R
R = 1860 Ohms
V(t) = V0 exp(-t/(L/R))
(4.86mA * 1860 Ohm) = 12V exp(-t/(L/R))
.753 = exp(-t/(L/R))
natural log both sides...
.28 = t / (L/R)
L/R = 0.0033
L = 6.18 H
However, MasteringPhysics does not accept this solution.
Derp. should've been using 1- exp(-t/(L/R))
V = IR
R = 1860 Ohms
What is V(t)? The voltage across what?
.28 = t / (L/R)
L/R = 0.0033
L = 6.18 H
You completely ignored the battery. It is present. You can consider the coil as an ideal inductor connected in series with its resistance and connected to the battery. The voltage across the inductor is not the same as the voltage across the resistor.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
