What Is the Volume Flow Rate of a Water Jet Impacting a Scale?
A vertical water jet with a 1 cm diameter impacts a bathroom scale, showing a reading of 5 kg, which translates to a force of 49.05 N. The area of impact is calculated as 2.5 x 10^(-5) m², leading to a pressure of 624.523 kPa. Using the dynamic pressure formula, the velocity of the water jet is determined to be 35.341 m/s. The volume flow rate is then calculated to be approximately 2.7756 liters per second. The discussion raises a question about the necessity of including atmospheric pressure in the calculations.
gikwiye
a vertical, 1cm-diameter jet of water impinges upon a bathroom scale such that the latter exhibits a reading of 5 kg. Estimate the volume flow rate of the jet.
p=F/A
Q(volume flow rate)=U*A(area where the jet of water is applied on)
a=pi*r²
F=mg
P=(rho*U²)/2 (if we consider that the pressure applied on the scale by the jet is essentially dynamic pressure) (don't know if this is correct though)
let's calculate A first
A=2.5x10^(-5)*pi
then let's change the kg into Newtons:
F=5*9.81=49.05N
P is F/A therefore: P=49.05/(2.5*10^(-5))=624.523kpa
with P=(rho*U²)/2 if find U=35.341m/s
and with
I find Q=2.7756 l/s
just want to know if I should include the atmospheric pressure or not
found it
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
